350 or 305?
Old Mar 5, 2004 | 12:42 AM
PILU's Avatar
Car: Firebird 89' and Formula 87
Engine: 2.8 l and 350 v8
Transmission: 2.8 Manual 5 speed and 5.7 manual 5 speed
350 or 305?
I just got a firebird 4 days ago, its is a v8 5 speed, it has edelbrock carburator, and edelbrock intake maniful, the car runs like a monster, I know for sure that the engine and the transmision are not from that car, because it used to be an automatic, and the engine is carburated, also alot of electrical stuff doesn't work (speedometer, tachometer, oil presure gauche, and the temperature gauche) the fuel gauche does work , it has a aftermarket temperature gauche that does work, and the radiator fan isn't electrical, it works with the water pump band.
I also know that the engine has some work inside, it has shorter pistons, and other stuff that I dont really sure.(the car isn't street legal at all in the states) doesn't have the smog band and neither nothing from the emisions, but is allright to drive it in mexico.
How can I tell if the engine is a 350 or a 305??
PILU
Old Mar 5, 2004 | 02:18 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
the quickest way is the casting numbers off the side of the block. Once you have those, you can head over to www.mortec.com and look it up.
Old Mar 5, 2004 | 08:57 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
The casting # is located on the top of the bellhousing section, driver's side. A lot of fun to find while the engine is in the car.
But, short of disassembly or a volume displacement test, that's the only way to know.
Old Mar 6, 2004 | 08:18 PM
PILU's Avatar
thanks, I'll try to look it out, hopefully is a 350
Old Mar 6, 2004 | 10:09 PM
86WS6_T/A's Avatar
Car: 2003 Mach 1
:werd: Plus, there's usually crap built up on the numbers so you might have to do some scrubbing to get to them.
The engine I bought had a rear main leak and had about an inch of sludge built up on the back of the motor...nasty stuff.
Old Mar 8, 2004 | 08:42 PM
PILU's Avatar
I did't found them .
but I have to change the carter gasket, because its leacking lots of oil, so I bought an gasket from 350 hopofully it'll fit. if not that means my car is a 305
Old Mar 8, 2004 | 09:44 PM
kd5boc's Avatar
Car: 92 RS
Could also be a 327.
It might show up as a 350 on teh casting, but I would also try to do a displacement check to see if it's a 327. (same block, shorter stroke.)
Don't always assume it's a 305 or 350. There are lots of guys who like the 327's too.
Old Mar 8, 2004 | 11:17 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
yes, but the amount of crankshafts from the 327 era that are large journal are not that common, other than aftermarket. IIRC, only 68 and 69 were large journals.
and no offense or anything, but why is this in the carb board?
Old Mar 8, 2004 | 11:40 PM
kd5boc's Avatar
Car: 92 RS
True...
LOL didn't even realize that LOL
Old Mar 9, 2004 | 12:54 AM
PILU's Avatar
my engine is carburator, I thought this would be the best place to post it
Old Mar 9, 2004 | 01:13 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
i wouldnt worry about it. this kind of stuff is generally posted in the tech/general engine section. But oh well. either way we'll still help you decipher your engine.
does Mexico have emissions
Old Mar 9, 2004 | 01:23 AM
PILU's Avatar
no, no emissions.
I'm runing both of my firebirds without cat, and the v8 i'm driving it without anything from emissions.
Old Mar 10, 2004 | 08:59 PM
Fast305's Avatar
Car: 1983 G20 Van
Engine: 305 4bbl
Transmission: Possesed 700r4
It could be any small block for that matter. Just hope it is not a 262.5, 265, or 267. It could be a 400 for all he knows. On the outside all small blocks look the same.
Old Mar 11, 2004 | 08:39 AM
five7kid's Avatar
I'm not sure what gasket you're talking about, but 305 & 350 oil sealing gaskets are the same. Only differences come with specific years, such as '86-earlier using perimeter bolt valve covers and '87-later using center bolt. But, both 305's and 350's changed the same year.
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
