Need help!How much does it cost to have a 305 carb pro cleaned and sealed?
Old Mar 20, 2004 | 11:29 PM
Rage2004's Avatar
Car: 1986 Trans Am Barris Custom from the short lived TV show Force 3
Engine: 305 4 barrel
Transmission: 4 speed automatic
I think the shop I went to is trying to rob me.
I have a 1986 305 computer controlled carb engine.
It needs to be soaked in carb fluid for 8 hours to get the varnished old fuel out,and get new carb seals.
It needs a new TPS sensor.(works intermittenly)
It needs a new O2 sensor.(dead)
New cap,rotor and distributor.(supposedly needs replaced)
The car has sat for 17 years and I have driven it on and off for near a year.It has only 1350 miles on it.All fluids and such were flushed and replaced.
How can the cap,rotor and distributor go bad from 1350 miles?Age alone?
Anyways...the shop wants about $830 to replace said parts and clean up.
Does this sound a little high or is it just me?
Any help is appreciated!
Any suggestions are appreciated too.
Attached Thumbnails Need help!How much does it cost to have a 305 carb pro cleaned and sealed?-aor_400x301.jpg
Old Mar 21, 2004 | 01:06 AM
83_1/2 L69's Avatar
Car: 83 Z-28 (Original owner)
Engine: 305 CC-carb
Transmission: Richmond 6-speed, Rear:3.73
Quote:
"How can the cap,rotor and distributor go bad from 1350 miles?Age alone?"
Saying the Distributor is "bad" sounds fishy, especially if the TPS is flaky, it can cause unstable timing. Please DO change the Cap/rotor. When plastics breakdown with age, they start conducting when exposed high voltage.
QUOTE:
"It needs to be soaked in carb fluid for 8 hours to get the varnished old fuel out,and get new carb seals. "
Ask them exactly which "seal" is leaking?
I cleaned my carb without taking it apart.
Pulled off the car,dumped the gas thru the bowl vent, filled with Gummout from a spray can into bowl vent, let soak, dump and repeat.
Old Apr 2, 2004 | 11:46 AM
wanderer's Avatar
Car: 82 Z28
Engine: 350 carb
With a car like that you should be more than happy to spend so little on such minor tune up requirements. Be happy that you don't have to tear down the powertrain and replace seals and gaskets due to dry rot. Stop your complaining about something so trivial when you have such an original and unique ride!
Old Apr 2, 2004 | 12:19 PM
Battery's Avatar
Car: 75 & 82 Z-28
Transmission: Saginaw 4 speed
I think you said it right on the nose. Spend so much on such a SMALL tune up. Do it yourself. They are not giving you a good price, or maybe it's just that shops are so expensive. Either way, everything that needs to be done will take you a day or so for your first time. Carb maybe a little longer, but why not learn?
Old Apr 2, 2004 | 01:25 PM
Jesus's F-Bird's Avatar
Car: 83 Pontiac Firebird S/E
Transmission: Borg Warner T5
Right, you could buy a whole *** damn carburator, brand spankin new, even one thats is superior for like 300-400 bucks. The you just bolt it in, and you go. If you want to keep the car stock, buy a rebuilt carburator from a machine shop or even a GM replacement catalog for about 200-300 bucks. Cap and rotor cost very little money, under 50 bucks. o2 sensor you could get at any parts store. Or you could save the money from buying a new carb, get cleaning fluid at a local car store, and just let it soak, i doubt it leaks, unless you notice that your car runs like ****. And Wanderer, 800 bucks is alot for some people, and this is a board to ask questions, so i dont belive you should be telling someone not to complain, if that was so, why even have a board?
Old Mar 4, 2010 | 03:13 PM
GtoRockz's Avatar
Car: 1987 Firebird
Transmission: R4
Axle/Gears: Stock
Re: Need help!How much does it cost to have a 305 carb pro cleaned and sealed?
Just had my carb professionally taken apart cleaned and adjusted. $197.00
May seem a little pricey but wow my car runs nice now. Worth every penny.
Old Mar 4, 2010 | 07:10 PM
RocketyMan's Avatar
Car: '96 Camaro-Vsux -- SOLD, '84 Z/28
Engine: 3.8L, 305 SBC
Transmission: 4L60E, T-5
Axle/Gears: 3.08s, 3.23s
$830?!!?!?!?
Highway robbery! Yeah..I agree with wanderer. Those are such trivial things you can do!
Old Mar 4, 2010 | 09:07 PM
csmith3's Avatar
Car: 70T/A, 87Formula, 02Hawk, 06 GTO
Engine: 400, 350, LS1, LS2
Transmission: M21, 700r4, T56, 4L65-E
Axle/Gears: 3:55, 2:77, 3:45, 3:46
You got an '86 with 1350 miles on it? Sweet! Welcome to Third Gen. Yeah, after sitting like that there will be some things that need to be addressed. How comfortable do you feel addressing these your self? When you're able to repair your own car there aren't many feelings that are better!
Old Mar 5, 2010 | 01:58 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You do realize this post is 6 years old, right?
Old Mar 6, 2010 | 01:30 AM
csmith3's Avatar
Thanks five7
Last edited by csmith3; Mar 6, 2010 at 01:31 AM. Reason: I'm a retard, can we still say that?
midge54
Dec 27, 2019 04:14 PM
Infested
May 22, 2018 11:56 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Exxon Limited
Aug 9, 2015 08:13 PM
