Demon w/ Air Gap Intake & Vacume Line
Car: YTG Camaro
Engine: 383
Transmission: TH-350
Has anyone had a problem getting a vacume fitting to fit under a demon carb with an air gap intake. This is for the power brakes line. The picture shows the inerference where I need about .25 inches more. I tried a couple 90 deg fittings the problem is that both requre an adaptor of some sort which adds to the stack height. I also tried a hose fitting but it also requires an adaptor.
Does this mean I need to get a spacer? I am allready concerned about hood clearance even with the low profile air cleaner I have.
Car: 82 Z-28
Engine: Built 406ci
Transmission: 700R4 w/3000 stall
Axle/Gears: 3.73 Torsen Posi, Moser Axles
Did you try one from an original intake that had a carb on it? I believe the 82-84's had the Rochester Quadrajet carb on them. I took mine off the original intake of my 82 Z-28 and put it on my Air Gap intake with the Holley carb. no problem..
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
why don't you grind down some of those threads to make the fitting effectively shorter so it'll thread in more closely to the base? that should give you the needed clearance.
Car: YTG Camaro
Engine: 383
I started to consider grinding the threads down some my concern is I may not be able to get far enough down.
I also didn't think I would pull enough vacume from the carb if I used it for PCV too. Is that always the case or does it depend on the cam? This sounds like the easiest thing to do.
Thanks for the quick replys. I am almost ready to get out of the garage!
Car: 83Z28 HO
Transmission: G Force 5 speed
I have the same problem with the fitting. I bought a Edelbrock "low profile" fitting and still, the carb won't bolt all the way down. I also need about 1/4" more clearance.
And I presently have a T fitting for my PCV and brake booster. Vacuum is not vacuum. I think the brake booster needs it's own dedicated source.
If you hook it up that way, you'll notice that your brakes don't operate as easy as they used to, and if you really need to step on them, your car may stall. Mine did - twice. But only during a hard sudden stop.
I'm getting a 1/2 inch wood spacer for mine, and I'm just hoping I can still close my hood!
Biochem
Aftermarket Product Review
Nov 14, 2000 11:52 AM
