Choke Light
Old Jul 20, 2004 | 11:06 PM
z28cmr83's Avatar
Car: 83 Z28, 84 Z28
Engine: 5.0 Cross Fire, 5.0 H.O.
Transmission: 4 Speed Auto, 5 Speed Manual
Choke Light
I started my car after being off for 4 months, i just did a head job and the carb was sitting off the car for those 4 months, when i started it up i had a check engine light and a choke light, i got rid of the check engine light but i have no idea how to get rid of the choke light. I have the quadrajet carb, and i have noo idea about carbs, but the little thing that flaps on the front of it is stuck open, im guessin that this could be the broblem. Can anyone help?
Old Jul 20, 2004 | 11:47 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
sounds like the choke is bad
Old Jul 21, 2004 | 12:30 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If the choke plate is stuck open, the choke may indeed be bad, but that has nothing to do with the light being on. Check the alternator.
Old Jul 21, 2004 | 06:41 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The choke circuit is arranged in such a way that the choke will nt receive its 12V heater power, unless the alt is charging. That keeps it from being heated while sitting still while the engine is on. However, it also means that if the alt goes out, the choke stays engaged forever and never pulls off. So, probably for emissions reasons (that being a serious emissions violation and the smog ***** wouldn't like that and there's no alternator ***** to complain about being hijacked) they labelled the "Alternator" light "Choke" instead of "Alternator".
The most amusing thing about it, is that for a number of years, even the cars (Crossfire and early TPI for example) that didn't even have a choke, still had their "Alt" warning lihgt labelled "Choke".
Replace your alternator.
Old Jul 21, 2004 | 08:54 AM
THEGENERAL's Avatar
now thats crazy i guess it costs too much for them to make a light that said alt on it ...lmao .....
Old Jul 21, 2004 | 04:51 PM
2 dope's Avatar
Car: 1985 Camaro Z 28
Engine: 305 LG4
my choke light comes on everytime i start my car, i ignore it
Old Jul 21, 2004 | 04:55 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The choke light is supposed to be on when the key is in the on position and the engine isn't running.
Old Jul 21, 2004 | 05:43 PM
2 dope's Avatar
Engine: 305 LG4
sometimes it does stay on after the car is started though
Old Jul 21, 2004 | 05:44 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
For how long? Sometimes it'll stay on for a few seconds until the engine comes up to speed.
Old Jul 22, 2004 | 10:20 AM
z28cmr83's Avatar
Car: 83 Z28, 84 Z28
yea you guys were right it was the alternator, the two wires that are held on by a nut on the back of the alternator were off, that was causeing my choke to stay open all the time and my battery to barely charge.
Old Jul 22, 2004 | 10:42 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Well that was cheap and easy. Wish they were all like that.
Old Jul 22, 2004 | 11:14 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That would keep your choke closed, you may still have problems with the choke.
Old Jul 22, 2004 | 02:18 PM
z28cmr83's Avatar
Car: 83 Z28, 84 Z28
well the light went out so whatever that problem was, it's solved
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
383cam
Sep 9, 2015 06:01 AM
TBRays98
Sep 6, 2015 05:05 PM
Jetmeck
Sep 4, 2015 12:29 AM
luvofjah
Sep 3, 2015 07:08 PM
