How do your carbs perform in cold weather?
Old Nov 29, 2004 | 11:44 PM
92RSSlowmaro's Avatar
Im planning out a carb'd 350 swap for my car, and I was just curious as to how you carb folk feel about your setups when old man winter comes around?
Old Nov 30, 2004 | 12:01 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
I drove an 84 Z28 carbed for six years with neary one single complaint. Worked better than all my friends fuelly trucks/cars at the time I used to have a place in North Bay Ontario where extreme cold is the norm in the winter and often it was my car that would start with nothing more than a pump to set the choke. The tirck is to have the choke set right and working properly. Of course if its an aftermarket carb then make sure the calibration is A1 as well as the choke. Carb tuning is a different world from fuelly no doubt but when properly set up will run every bit as well as FI
Old Nov 30, 2004 | 12:07 AM
Good enough for me! I still have a bad taste in my mouth from this 82' S-10 (carb'd 2.8) I used to own. Sucker wouldn't run when cold unless I stood on the throttle.
Old Nov 30, 2004 | 12:13 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Haha I hear that... yeah but those carbs were the crappy wierd two barrel bizzaro rochester 2SE POS that only made it onto a few cars No fears of carbs nec cause any Rochester four barrel or Holley can be set up to run aces all year round
Old Nov 30, 2004 | 02:20 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
How long have carbs been around now? Obviously they can run good in all 4 seasons, IF THEY ARE SETUP RIGHT.
Old Nov 30, 2004 | 04:26 AM
contactpatch's Avatar
Engine: sbc 350
some advice...
--> buy a battery tender <--
also, put in 5w-30, or 0w- 30, oil
Old Nov 30, 2004 | 11:46 AM
305Tiger's Avatar
Car: 1987 Trans Am
Engine: LG4 305 w/emissions & A/C delete
Transmission: "...check!"
Axle/Gears: it's crap...they're stock!
Here in Michigan(Det. Metro area) my carb works fine 99% of the time in the winter(so 6 months of the year) and that 1% when it does'nt work too well is only because I need a new air filter element(I change mine two times a year; winter & summer).
-G
Old Nov 30, 2004 | 10:19 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
Mine runs just fine here in the houston area where the weather changes drastically everday. It goes from cold and rainy to warm and humid back to cold or sometimes just rainy and my carb runs about the same through it all. Like stekman said it just needs to be set up right.
Old Dec 1, 2004 | 08:27 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Ummmm not trying to flame here man but have you ever been to Canada? Its not uncommon to have over 90 degree fahrenheit temp changes inside of 24 hours from minus 40 to plus 50 or so. In the winter the temps change a minumum of about 35 to 40 degrees difference between daytime high and nightime low. Thats only in the South of Canada...
Get up in the North and most people never shut their vehicles off cause you won't get them running again after as little as fifteen minutes. Whats real funny is in every parking lot whether it be for Hotels or Home Depots there are electrical outlets at every parking space so you can plug in your block heater while you leave your vehicle. No joke man this is true. When the militery runs exercises up North they always have someone on fuel watch to keep the machines full so they don't run out and stall otherwise they will not get them restarted. Thats usually only in the way North though where temps of minus 120 or so are common. I would gladly change for Houston weather
Old Dec 1, 2004 | 08:30 AM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
My carb never gives me much trouble. Sometimes it's a little hard to start, and sometimes the choke doesnt work right, but that's not the carb's fault, that's mine for putting off a well-needed cleaning and tuning.
Old Dec 1, 2004 | 09:43 AM
Bobbyz's Avatar
Car: 87 IROC Z "ZZ4"
Engine: 350 "ZZ4"
Transmission: ck performance th400 3000 stall
Axle/Gears: 3:73 10 bolt
Only complaint with my holley in cold weather is i have to warm it up good before i go or she bog's down on me until she is warm.
Old Dec 3, 2004 | 09:24 PM
fake formula's Avatar
Car: 1986 z28 camaro
Engine: 305 4bbl
Transmission: t-5
my carb stumbles in the morning a little but because I dont have a choke on it, but other than that, Ive never had trouble with carburators as far as all 4 seasons go
Old Dec 8, 2004 | 09:21 PM
BAD91CamaroRS's Avatar
Car: 91 Camaro RS 383
Engine: carbed 383
Axle/Gears: 3.42 posi
Bobbyz Only complaint with my holley in cold weather is i have to warm it up good before i go or she bog's down on me until she is warm.
My holley 650 double pumper is the same way, I'm going to change to a electric choke and see if that helps. Good think I dont drive it in the snow when its really cold out.
Old Dec 9, 2004 | 01:48 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
My Holley starts on the first crank up here in the Great White North. It was harder when it had a manual choke, so the electric choke was a HUGE upgrade, made ALL THE DIFFERENCE!
(BTW - I have NO warm air going to it either... the exhaust crossover in the manifold is blocked, and no heat riser to the aircleaner!)
Old Dec 9, 2004 | 04:21 PM
86iroclamarque's Avatar
Car: 1986 IROC
Engine: 305ci DEAD FINALLY! 350 almost ready to go in!
Transmission: 700R4/Coming out TH-350 going in!
i'm running Q-Jet with my choke messed up right now and it starts ok after the 2nd try. i do have to let it warm up to stop it from bogging down. Gotta get in choke soon though. my last f body was a fuelly and i like the carb better.
theshackle
Sep 17, 2020 08:26 AM
Infested
May 22, 2018 11:56 PM
beastin91rs
Oct 9, 2015 07:38 AM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
