Carb ID Numbers
Old Sep 10, 2005 | 07:55 PM
unklechuckles19's Avatar
Car: 1987 Z-28
Engine: 355
Axle/Gears: 10 Bolt/3.23 peg leg :(
Carb ID Numbers
So to make a long story short, after a blown T-5, and a bunch of other misc. bad luck that happened, i finally have my car home, first time since i baught it, back in July. so i took off my dual snorkel to take off the valve covers and have a looksie, it looked good. but to my suprise, i found a holley DP sitting on top of my stock intake i didnt take it off, but i did see on the drivers side the number 12R-10858B. i looked on mortec.com to see if anythying matched up, and couldnt find anything. am i looking at the right numbers or do i have to take it off to look? i can tell there are vac. secondaries, and its a DP, but im not sure what CFM it is. are these the right ID numbers or are there different ones i couldnt find?
Old Sep 10, 2005 | 11:55 PM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
The carb should have a idetification Number starting with an R. either on the airhorn, or on the top of the carb. it should be easily seen on the main throttle body.
for my 4160 the number is 80462
There is an "R" in front of it.. thake another look... the number you gave is for the throttle body itself, there are four carbs that use that main body. You could do a search on the holley website. they will tell you where you can find the number. I have the part number listing from theier site.
Old Sep 11, 2005 | 12:06 AM
OK. i did a little looking and i found where the numbers should all be. and i will quote
QUESTION How do I find the "list" number on my carburetor?
ANSWER The list number for most performance and factory 2 and 4 barrel carburetors will be found stamped into the upper right hand corner of the airhorn or sometimes called the choke tower. On the 4150 HP models that do not have a choke tower the list number will be stamped into the mainbody behind the throttle linkage. This number is used to identify the carburetor and also used when needing service parts or renew kits."
that should let you know exactly where they can be found
Old Sep 11, 2005 | 02:13 AM
Car: 1987 Z-28
Engine: 355
thanks alot guys ill go out and have another look tomarrow when it gets light out again!
Old Sep 11, 2005 | 03:16 AM
your welcome. if you find that number i should be able to pull up some specs for you
Old Sep 11, 2005 | 11:25 AM
Car: 1987 Z-28
Engine: 355
still no luck, thats the only number i could find. if im looking at the car from the front, should i be on the drivers or passenger side? im gonna go out and keep looking, and see what i can find.
Old Sep 11, 2005 | 11:28 AM
Car: 1987 Z-28
Engine: 355
HA I WIN! i found it, i wasnt looking quite hard enough, heres that number R-84014-11285. thanks for all your help!
Old Sep 11, 2005 | 01:20 PM
You have a 4011 Series holley carb. It is 650 cfm, uses holley renew kit 37-1541, Needle and Seat are - 6 - 504, the Power valve is a 15. Primary pump nozzle size is a 0.026
Happy carbing
Old Sep 11, 2005 | 01:35 PM
Car: 1987 Z-28
Engine: 355
wow, thanks for all the info, really appreciate it. where did you get all this info?
Old Sep 11, 2005 | 02:24 PM
Right from the holley web site www.holley.com under thier tech area. they have tons of info about all of thier products including exploded rebuild views and such..
Old Sep 11, 2005 | 02:26 PM
note however that trying to read some of those views is close to impossible lol.. the best thing you can do now that you know the model number of your carb is to get a HOlley carb book that deals with that carb. that way you will know all there is to know about tuning it and everything.
Old Sep 11, 2005 | 10:25 PM
Car: 1987 Z-28
Engine: 355
thanks a bunch again!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
383cam
Sep 9, 2015 06:01 AM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
Billy Decker
Sep 4, 2015 03:46 PM
GeneralIesrussi
Sep 3, 2015 03:23 AM
