thoughts on weiand X-celerator intake
Old Jun 25, 2006 | 08:01 PM
Hodge's Avatar
Car: 1987 IROC-Z28
Engine: 383 Vortec - carb
Transmission: T56 - 6speed
good or bad. considering going with this on my 383. the vortecs are gone and dart 215's are coming in, so I need to change intakes.
Old Jun 26, 2006 | 02:10 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Please get rid of the SA. Then I could agree with your combo using an X-CELerator.
Old Jun 26, 2006 | 05:54 PM
Hodge's Avatar
Car: 1987 IROC-Z28
upgrading the carb is first on the list after I get the car running again. right now I just want to be able to drive it again.
I should probably mention that the car is just a fair weather car not a daily driver and it sees mostly street time when it comes out, with about 6-8 trips to the track a year.
I was running an Edelbrock RPM air gap on my vortecs and have considered staying with one of those. Will the X-CELerator give me much more top end than and RPM would?
Old Jun 26, 2006 | 08:48 PM
Irockz's Avatar
Car: 87 Berlinetta,work in progress
Engine: 468 BB,still in the build process
Transmission: TH350,3500 stall
Axle/Gears: 9" Ford,learning how to live under
VERY little,if any.Get an RPM for the new heads,or a Weiand Stealth.The X-celerator is 70s technology,they just aren't up to par for today's camshaft profiles and cylinder heads.
Old Jun 27, 2006 | 11:19 AM
Hodge's Avatar
Car: 1987 IROC-Z28
well I continued looking for info about the X-CELerator and finally found something useful. Someone was just making observations on it by looking at the ports etc. and mentioned that the angle that the ports meet the heads causes the air to make a sharp turn going into the head. So that one is off my list but now I like the look of the Team G manifold. any thoughts on that one?
Old Jun 27, 2006 | 01:16 PM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
I had a Team G before swapping to FI. Before that I had a Street Dominator. Very noticable difference from 3500 rpm up.
Old Jun 27, 2006 | 04:16 PM
Hodge's Avatar
Car: 1987 IROC-Z28
Are you saying that the Team G was better than the street dominator?
Old Jun 27, 2006 | 09:22 PM
Irockz's Avatar
Just my ,and worth just what it costs you,but not knowing what cam your running,nobody can give any solid advice.
IMO,if you only make a few trips to the track a year,I'd still stick with my earlier advice of an RPM or similar intake.
Yes,a Team G or Vic jr. will produce better high RPM power.But just for cruising and stoplight fiascos,the RPM type intake is going to out do the single plane almost every time.
Unless you have a massive cam and very loose convertor,I still vote for an Air Gap RPM.
Old Jun 27, 2006 | 11:05 PM
Hodge's Avatar
Car: 1987 IROC-Z28
cam is 236/236 @ .050 with .555/.555 110LSA trans is a T56.
A lot of times when I am cruising around it is with friends driving modified LS1's so I was kind of wanting an intake that'll run on the top end since these guys like to run from a roll.
Old Jun 28, 2006 | 12:40 PM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
Yes. The loss in low end torque was barely noticeable, but the top end was considerably better.
Old Jun 28, 2006 | 05:25 PM
Hodge's Avatar
Car: 1987 IROC-Z28
Cool.
I just bought the Team G last night. thanks for the input everyone
1992 Trans Am
May 10, 2023 07:19 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
86White_T/A305
Aug 17, 2015 12:16 AM
