Computer controlled quadrajet Gas mileage
Car: 1983 G20 Chevy
Transmission: 4L60
Originally Posted by berlincam86
How many miles on a tankfull are you getting with your quadrajet?
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
you are getting good mileage berlin.
I got just over 200kms on a tank, and I think that was about 20MPG, with my non overdrive LG4 setup.
Car: 1992 Z28
Engine: 350 tpi
Transmission: 4L60
Well I thought I was getting bad gas mileage. Guess thats all I'm going to get with this carb. How much of an improvement would I get if I fuel injected it?
Transmission: 4L80E/4L80E
Last time I filled up, I had put in a few gallons inbetween to tide me over at the track. So, I went 404 miles between fill-ups. There was stop & go, highway, and 10 1/4 mile passes included in those 404 miles. Took 20 gallons total for 20.2 MPG. That's a little over 300 miles on a 15 gallon tank.
I've recorded as much as 27 MPG on straight highway miles.
Sonic, something is wrong with your figures. 200 kilometers is 124.27 miles - if you used 15 US gallons in that distance, that's 8.24 miles per gallon.
Car: 85 z28 and a 97 ford ranger
Engine: 305 carb and a 4cyl pos
Transmission: both have a 5spd
on my 85 i see about 300 in between fill ups and i only put in about 11 gallons in when i fill up so i seem to be getting some descent milage... the funny thing i get the same as my girlfriends 02 mercury cougar v6... she hates it... lol
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
Per tank is a lousy measurement of fuel mileage. Please measure mileage in MPG.
That said, my mileage for my thirdgen was 19.5 city and 24.5 highway. I was running a ZZ4 crate on the full computer setup, '84 sport coupe (no gfx), '95 T56 trans (0.5 6th gear) and a 3.89 Ford 9" rear axle.
Car: 1986 Firebird
Engine: LG4 305
14 city/ 21 Highway with 5sp and Quadrajet'd 305 -- pretty sucky.
Oh yeah, I've also got the 3.40 rear end.
Anybody know if headers/high flow cat etc makes a difference in mileage?
Car: 84 Z28 H.O. w/Megasquirt II
Engine: semi-stock L69
Transmission: T-5 non W/C
Axle/Gears: 3.73 open
Yes, freeing up the exhaust is an excellant way to up the mpg numbers.
The more efficent your motor runs, the better milage you shall recieve.
Although, I have found the biggest gains while I had a (temporary)reduction of right-foot leaditis. Keepin out of the throttle makes a huge difference.
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
Back when my '84 was stock, I kept track of fuel mileage for every tankful from 1990 through 1998. It was a 3.73:1 rear gear, 700R4, 305 H.O. and on the highway I got 20.5 to 22 MPG, and around town it was 16 to 17 miles per gallon.
Pizza guy is right though - If you granny the car and always stay out of the secondaries, you can net great gains in fuel mileage, typically 3 to 4 MPG.
eightsixseven
Dec 16, 2024 01:50 PM
colton_carlson
Mar 8, 2019 12:21 PM
