tachometer hook up on tbi-carb swap!
Old Sep 14, 2007 | 08:18 PM
chevycamaro91's Avatar
Car: 91 camaro
Engine: 383 stroker
Transmission: t5 :(
Axle/Gears: posi 373
i swapped out my tbi motor for a carb'd on my 91 rs and need information on how to hook up my tach. im not too familar with distributor and stiff but i do no that my new dist. is not computer controlled. its an msd with a 6a box and coil. on my dist. theres a plug that connects it to the 6a box. and from 6a box theres 2 wires that go to the coil (pos/neg) and also a wire that goes from dist. cap to coil. does any one have information on how i can hook up my stock tach to this set up? ive included some picks to help explain it a little better.
Attached Thumbnails tachometer hook up on tbi-carb swap!-picture-007.jpg   tachometer hook up on tbi-carb swap!-picture-006.jpg
Old Sep 14, 2007 | 08:36 PM
jonmark1985's Avatar
Car: 89' Pontiac Firebird
Engine: L03 carb Ported #87s new shortblock
Axle/Gears: 2.73 open
Re: tachometer hook up on tbi-carb swap!
I believe it is a white (might wait for someone to confirm) wire that ran to the negative side of the OE coil, you want to hook it to the negative side of your aftermarket coil. Thats the route i went.
Old Sep 14, 2007 | 08:41 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Don't put it to the coil. If you do that with an MSD you'll fry the tach. Connect it to the tach terminal on the box.
Old Sep 14, 2007 | 08:42 PM
Car: 91 camaro
Engine: 383 stroker
Transmission: t5 :(
alrihgt cool thanks for the tip. im gonna try that out this weekend, thank for the help man
what do u mean by tach terminal?
Last edited by chevycamaro91; Sep 14, 2007 at 08:44 PM. Reason: Automerged Doublepost
Old Sep 14, 2007 | 08:45 PM
i believe msd boxes have an extra wire or spot for the tach, im not a fan, i dont worry about them
sorry about the bad advice on the box
Old Sep 14, 2007 | 08:56 PM
Car: 91 camaro
Engine: 383 stroker
Transmission: t5 :(
alright i just wnet and checked my msd box and it does have a tach hookup that i never noticed before. so would i hook up the white wire to the tach input?
Old Sep 14, 2007 | 09:06 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Right, whichever color wire it was that connected to the tach terminal on your original distributor.
Old Sep 14, 2007 | 09:21 PM
Car: 91 camaro
Engine: 383 stroker
Transmission: t5 :(
well thanks for all the info. ill be wiring it up this weekend some time
Old Sep 14, 2007 | 09:22 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The MSD 6 installation instructions have pretty much every wiring diagram you could ever need.
Old Sep 14, 2007 | 09:31 PM
Car: 91 camaro
Engine: 383 stroker
Transmission: t5 :(
yea i lost my instructions a longg time ago haha. but i have it pretty much figured out
but i do have another issue: my speedo. i removed my ecm so is there a way to hook it up again??
Old Sep 14, 2007 | 09:33 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
http://msdignition.com/1download.htm
As long as your wiring isn't butchered, you don't need to reconnect the speedo.
Old Sep 14, 2007 | 09:37 PM
Car: 91 camaro
Engine: 383 stroker
Transmission: t5 :(
alright man thanks for all the help ill let ya know how it turns out
Old Sep 15, 2007 | 09:04 PM
z28z34man's Avatar
Car: 1984 z28 camaro / 2019 accord sport
you might need to remove the tach filter i know i had to on my 84
Old Sep 15, 2007 | 09:08 PM
Car: 91 camaro
Engine: 383 stroker
Transmission: t5 :(
tachfilter?? where would i find that
Old Sep 15, 2007 | 09:13 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Follow the tach wire back to the firewall. You might not even have a tach filter.
z28z34man's Avatar
if i remember right it is a little black or is it silver cylinder on the fire wall it should be in series with the tack i believe.
Old Sep 15, 2007 | 09:17 PM
Car: 91 camaro
Engine: 383 stroker
Transmission: t5 :(
i cant recall seeing anything like that so im goin to hook the white wire tot he "tach terminal" port on the ignition box and see what happens
midge54
Dec 27, 2019 04:14 PM
deracer
Apr 11, 2016 12:04 AM
IroczFan
Oct 6, 2015 10:13 AM
ChevyZ71
Aug 13, 2015 07:30 AM
