Carbed rev limiter
Old Sep 18, 2007 | 07:50 PM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
Transmission: T5 non-W/C
Axle/Gears: 3.27 Open
Carbed rev limiter
Can you have a rev limiter with a carbureted car? My car has cruise control so shouldn't it be able to have a rev limiter. If anyone knows how to install one or programm it in let me know.
Old Sep 18, 2007 | 08:10 PM
3rdgen92maro's Avatar
Car: 1995 Firebird Formula
Transmission: Th350/4k stall
Axle/Gears: 10 bolt with 3.42s
Re: Carbed rev limiter
yes u can have a rev limiter with a carb. just use a MSD ingintion box. they have them where u just change the pills in them to set the limiter where u want it.
Old Sep 18, 2007 | 08:29 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
...Why would cruise control have anything to do with a rev limiter?
I second the above statement though. Many aftermarket ignition options include a rev limiter feature.
Old Sep 19, 2007 | 03:00 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Yeah just search summit for rev limiters, there are a few.
Old Sep 19, 2007 | 03:29 PM
atc3434's Avatar
Car: 1986 Camaro SC
Engine: Bolt-on/cam 305
Transmission: 700R4 w/ 2500stall
Axle/Gears: 3.73 10bolt Posi
Right foot...
These guys are right, there are a variety of aftermarket rev-limiter and ignition control options. On a mostly stock car its not of much important, especially with an automatic.
Old Sep 19, 2007 | 06:46 PM
EvilCartman's Avatar
Car: '82 Z28
MSD 6AL box here with a 7,500 chip in it. I've hit it a few times in the burnout box or just playing around on the street.
Old Sep 19, 2007 | 07:47 PM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
i have a standard, and i figured that if the computer can control my throttle for cruise control then it could control the throttle for a rev limiter. But i planned on an msd ignition already so i'll go with that. New fuel injected cars computers cut the gas off for rev limiters, so i had a feeling you might not be able to do that with a carb considering its mostly mechanical. Thanks.
Old Sep 19, 2007 | 09:54 PM
atc3434's Avatar
Car: 1986 Camaro SC
That is correct, fuel cut on a carb is not possible. Modern fuel injection systems cut fuel as opposed to spark because cutting spark places unburnt fuel in the exhaust, sensors and cat converters don't like that very much. The cruise control only works as a pull on the throttle cable, and would in no way be able to limit revs.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
gta892000
Aug 11, 2019 11:16 AM
customblackbird
Oct 1, 2015 04:30 PM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
