Cleaned carb and now it idiles high.
Old Mar 3, 2008 | 04:22 PM
ino's Avatar
ino
Car: 87 firebird
Cleaned ccQ-jet on sat. and it idiles at 1200. Used the claener in a can, sprayed the outside and a few squirtes in the front barrells. What is the problem?
Old Mar 3, 2008 | 04:34 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Cleaned carb and now it idiles high.
Is it idling high while it's warm or while it's cold?
Old Mar 4, 2008 | 05:05 PM
ino's Avatar
ino
Car: 87 firebird
Actually, it does it all the time now. When warmed and cold. It acts like it stuck on part throttle cuz I can tap it like on cold mornings and the rpm will go to 650. But, as soon as I start driving it will shoot back up to 1200 and stay stuck there all the time now. If I'm at a red light or stop sign, its always 1200.
Old Mar 4, 2008 | 05:19 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Is your choke open or closed when it idles high?
Old Mar 4, 2008 | 06:43 PM
ino's Avatar
ino
Car: 87 firebird
When cold its closed but as soon as I turn the car on it opens. Even when warm the front barrells are open and the choch linkage is all the way down.
Old Mar 4, 2008 | 07:07 PM
scooter500's Avatar
Car: 87 Camaro Z-28
Engine: 305 LG4 w/ E4ME carb
my car's idle recently stayed high like yours. the electric choke wire came off. the choke looked open but linkage was stuck. the fix was to reconnect electric choke wire and press down 1x on large choke cam until the choke came unstuck
Old Mar 4, 2008 | 07:15 PM
ino's Avatar
ino
Car: 87 firebird
The wire is on, maybe the wire got wet but I will try that tonight and see what happens. thanks
Old Mar 5, 2008 | 11:32 AM
ino's Avatar
ino
Car: 87 firebird
Tried that and nothing still the same. Adjusted the choke counterclock wise and now it idles at 1700. Will put choke back becuse now it wastes more gas
Old Mar 5, 2008 | 01:52 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Doesn't sound like your choke is working properly.
Old Mar 5, 2008 | 04:47 PM
ino's Avatar
ino
Car: 87 firebird
Maybe, do u know where I can find a choke besides a junkyard. I have been calling to dealerships and they are discontinued.
Old Mar 5, 2008 | 06:25 PM
ino's Avatar
ino
Car: 87 firebird
Choke is fine. Was looking at it after work with my brother and he found the solenoid on the throttle bracket was bad. he disconnected it and it idles fine. Is the solenoid adjustable? Will post pics of solenoid later.
Old Mar 6, 2008 | 04:32 PM
ino's Avatar
ino
Car: 87 firebird
The solenoid is the one on the bottom left hand corner. I have not had a problem since it was disconnected.
Old Mar 6, 2008 | 05:10 PM
five7kid's Avatar
https://www.thirdgen.org/forums/carb...e-rebuild.html , figure 6C1-8I. A/C idle solenoid. It should only be powered when the A/C or defrost is on.
Old Mar 7, 2008 | 04:10 PM
ino's Avatar
ino
Car: 87 firebird
If I barely tap the throttle it will stay stuck in that position at a high idle. No matter what I do it stays like that.
Infested
May 22, 2018 11:56 PM
MantyZ28
23
Sep 29, 2015 11:33 AM
mdtoren
Aug 23, 2015 12:52 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
