Double pumper Q's
Old Apr 9, 2008 | 05:06 AM
valleyguy's Avatar
Car: 1986 Trans Am
Engine: 350 4BBL
Axle/Gears: 3.70
Double pumper Q's
Ran the numbers on my carb and found out it was a 600 cfm DP holly list number 4776-2 (1587) not sure what the rest of the numbers are but anyway I was just wondering whats the difference in a DP and a normal carb other than the obvious two fuel lines and bowls but is there performance to be had with it or what? Current setup is 80 350 block .30 over 64-67 327 camel hump heads and a wiend intake and the carb above. Also when the car comes out next month you will be hearing from me about tunning cause its not running right and you all will be happy to know that I intend to do all the carb rebuilding myself and tunning.....cause its the only way I will figure it out haha done plenty of work on my own stuff but never on a carb so it should be interesting.
Old Apr 9, 2008 | 08:07 AM
lukn4trbl's Avatar
Car: 2000 SS, M6
Engine: Modified LS1
Re: Double pumper Q's
For your street engine, you will likely not see any gains...unless you
drive wide open for long periods of time.
The obvious benefit of the dual fuel line is that you have equal inlet
pressure at each bowl instead of the rear feeding from the front line.
You may notice an improvement on the drag strip as the secondary
bowl has a more constant pressure and maintains a better air/fuel
mixture for the cylinders feeding from the secondaries.
The extra squirter can help you tune out wide open blasts on the
secondary side as well.
Old Apr 9, 2008 | 10:36 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Since you have a T5, the double pumper is the better choice. Throttle opening will be a direct correlation to accelerator pedal movement, which isn't the case with vacuum secondary or air valve type carbs.
Old Apr 9, 2008 | 03:17 PM
valleyguy's Avatar
Car: 1986 Trans Am
Engine: 350 4BBL
Axle/Gears: 3.70
Great, thanks for the info. I went out today and bought a rebuild kit for the carb so as soon as the car comes out of storage and I can work on it I will be doing the rebuild. It leaks fuel anyway so I figured I should just replace everything with new parts. So I'm sure you will see some post's from me on that subject haha...... I just got done looking at my rebuild kit and the instructions make it look a little itimadating (sp?) especially with all those small washer like gaskets...and as for the instructions all there is is an exploded view of the carb all tore apart.
Old Apr 9, 2008 | 04:11 PM
five7kid's Avatar
The numbers in the exploded view are the order for disassembly. Assembly starts with the larger numbered parts down to the lower numbered parts. Adjustment details are on the following pages.
Old Apr 9, 2008 | 04:15 PM
valleyguy's Avatar
Car: 1986 Trans Am
Engine: 350 4BBL
Axle/Gears: 3.70
I read through the instructions and got the gist of what the diagram was showing but holy there is alot of little parts...I can see some spare parts layin on the table after this job..lol
Old Apr 9, 2008 | 04:31 PM
five7kid's Avatar
I put an old bath towel on the workbench. Part #1 goes in the upper left corner of the towel, #2 to the right of it, so on across the top of the towel. Then start a new row if necessary on the left side again, etc. Assembly starts at the lower right moving to the left & up. I leave parts that will be replaced in their place in the order, and when the new kit part goes in, the old part goes to a can off to the side (don't throw them away until the whole thing is together and running).
Old Apr 10, 2008 | 04:38 AM
valleyguy's Avatar
Car: 1986 Trans Am
Engine: 350 4BBL
Axle/Gears: 3.70
Sounds like a good idea, thanks for the tip. I think if I can find one I might pick up one of those holly carb books I think it has more detailed tear down info and has alot of tunning info as well....I would like to learn as much as possible before I tear into it that way I'm not wondering what this part or that part does.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
grngryoutmyway
Oct 18, 2016 05:48 PM
skinny z
Oct 5, 2015 06:23 PM
thekurlyone
Sep 30, 2015 12:54 PM
buckshot63
Sep 10, 2015 09:15 AM
