What is taller?
Old Oct 17, 2008 | 04:52 PM
Jammin'Trey's Avatar
What is taller?
A performer RPm air gap or a Torker II? it seems like it will be a squeeze to get my motor in with a torker II. But I know the Performer RPM air gap fits ok.
Old Oct 17, 2008 | 05:01 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: What is taller?
The Torker II is over an inch shorter. You're not actually choosing to use that piece of dung over an Air-Gap, are you?
Old Oct 17, 2008 | 09:38 PM
Re: What is taller?
I already have one< so I will use it.
Old Oct 17, 2008 | 10:11 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: What is taller?
The Torker is probably worse than no intake at all.
Old Oct 20, 2008 | 09:54 PM
82Five-O's Avatar
Car: 82 Sport coupe
Engine: 355 semi roller
Transmission: TH-350 B&M ratchet shifter
Axle/Gears: 3.73 Eaton Posi
Re: What is taller?
whats wrong with a Torker? i have an old streetmaster that is essentially the same thing. i love the high rpm power.
Old Oct 20, 2008 | 10:00 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: What is taller?
It's an obsolete design. The low end suffers because of the undivided plenum, but there's not enough volume for it to really perform at the top end. A more modern dual-plane like the Performer RPM will beat it across the entire range.
Old Oct 20, 2008 | 10:04 PM
82Five-O's Avatar
Car: 82 Sport coupe
Re: What is taller?
Nice answer! i was pullin your leg to see what you'd say. I am displeased with the lower rpm range of my manifold, matter of fact, i have a performer air gap RPM in my garage ready to be installed. I hope you don't mind me having a laugh at your expense friend. but i totally agree with you.
Old Oct 21, 2008 | 11:26 PM
Gibbyzracing's Avatar
Car: 91 RS Vert 86 Cutlass
Engine: Sbc
Transmission: T5 400 Turbo
Re: What is taller?
The rpm air gap is a great intake but grab a Edelbrock scorpion or Victor JR.. best way to go for performance IMO
but the torker is ok for street driving not racing
Old Oct 22, 2008 | 11:45 AM
nhrata's Avatar
Car: 82 pontiac t/a
Engine: 23 deg headed 434ci sbc
Transmission: rossler T350 with brake
Axle/Gears: moser 9" ford 4.56
Re: What is taller?
I have never been a big fan of the torker intake . the performer air gap is a nice street manifold and with work the victor Jr is great . but for out of the box performance I like the Holley strip dominator imo
Old Oct 22, 2008 | 03:25 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
Re: What is taller?
if were talking small blocks.
RPMs and RPM airgaps are the same height, ive had a camaro and firebird with both.
The RPM air gap will fit with a thin gasket with about an inch of clearance under a firebird hood, using a drop base with a 3" air filter. It will also fit if you use a 1/4" gasket under the firebird hood, but some "trimming" of the under hood frame is required. Quarter inch gasket wont work on a camaro. Matter of fact, i dont know if a holley carb (dual fuel inlet style) will work in a camaro.
An edelbrock or a carter with a drop base and a 3" air filter on the rpm manifold will work fine in both cars.
Whatever you do, if you use this manifold, MAKE SURE the threaded stud that goes into the carb, is SHORTER than the wingnut on top. Otherwise you will have a nice "bump" in the middle of your hood.
Also you will have slighty less clearance, depending on how old your motor mounts are.
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Feb 13, 2016 10:04 PM
New2Chevy
Sep 28, 2015 12:35 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
85_ZED28
Jan 3, 2002 01:53 PM
