82-84 trans am factory ram air set up
Old Jan 24, 2009 | 07:18 PM
Jakout125's Avatar
I believe in 82-84 they made a factory ram air set up for under the hood, I was wondering if anybody knew how much one would run me, or how much they sell for if anybody seen them being sold, I dont want to pay a lot of money for something that isnt worth their price.
Old Jan 24, 2009 | 07:44 PM
FormulaL98's Avatar
Car: 88 Formula, 72 Nova, 68 Chevelle
Engine: L98, mild 350, L79 327
Transmission: 700R4, M20, M20
Axle/Gears: 9b 327,10b 373, 12b 331
Re: 82-84 trans am factory ram air set up
There was no Ram-Air system for third gen TA's. What the early HO cars used was a cowl induction system, meaning air is supplyed via a positive pressure effect at the base of the windshield. This system used a specific air cleaner assembly which more than likely isnt exactly easy to find nor cheap. Also a turbo hood will be needed with the induction flap at the rear of the scoop. This hood was used on pre 85 TA's and all Formulas.
Old Jan 24, 2009 | 10:16 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
The factory ram air setups used on '82-84 T/As aren't worth that much. You should be able to pick up a complete setup for under $100. Make sure you get the underhood peice from a carburated car as one from a Cross-Fire Injection is different.
Old Jan 25, 2009 | 12:39 AM
BirdoFireTA84's Avatar
Car: Trans Am
Engine: 5.0L 305
I believe I have one laying around. I have two 84 TA's that came with that setup. If you have trouble finding one at a reasonable price, send me a PM as I likely won't be using one of them. Both are from carbed setups.
Old Jan 25, 2009 | 09:49 AM
jjlabinski's Avatar
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: Torsen "3.73"
Yeah I got one for sale as well. Mine includes the K&N airfilter.
If you want it functional you will need the relays and switches.
I have all that stuff as well.
Make me an offer it is already shrink wrapped and packaged.
Jeff
Old Jan 25, 2009 | 12:33 PM
TylerP's Avatar
Car: 89 T/A and 97 Formula (sunny days)
Engine: 305 TBI / LT1
Transmission: 700R4 / 6M
Axle/Gears: 89 IDK / 97 3.73
I found a factory cold air hood on Craigslist. I posted a wanted add in the auto section and got several responses. My 89 has the flat hood and I figured if I'm going to change the hood I may as well go functional. I found the breather assembly on ebay for around $70 shipped. The hood cost me $175 and I drove 2 hours to get it but it's nice & straight,I just need to paint it. The crossfire induction plastic is different than the carbed part as mentioned above. I have one of each.
Where does the power wire hook up to on the air induction electric motor,anyone know?
Old Jan 25, 2009 | 02:13 PM
Dens71TA's Avatar
Power comes from a oil pressure switch, to a cold feed switch that senses engine temperature so it won't open with the engine cold, and then to a low vacuum sensor that will open the flapper door during acceleration and WOT situations.
Old Feb 2, 2009 | 08:35 PM
astrosurfer's Avatar
Car: 84 trans am
Engine: 305 5.0L HO
Transmission: TH350
mines hooks to the vac switch on the DS firewall nearest the hood hinge.
1 single wire I believe.
This should have vac attached for functionality.
Old Feb 2, 2009 | 08:49 PM
blg0720's Avatar
Car: 88 GTA
Engine: 305 V8 LB9
Transmission: 4 sp. Auto-4L60
So, if your car has the functional cowl, does that automatically mean that it's a 305 HO? I'm so new to these that I can't tell whether I have an HO or not even though I know it's a 305 V8.
Old Feb 2, 2009 | 09:03 PM
Dens71TA's Avatar
Originally Posted by blg0720
So, if your car has the functional cowl, does that automatically mean that it's a 305 HO? (
No. All Crossfire Injection and '83-84 carburated Trans Ams got the functional hood louver. Some magazine articles mention that late production '82 carburated cars would be getting the functional hood louver system but I've never seen any.
The 8th digit in the VIN is the engine ID.
VIN H = LG4 305 4-bbl
VIN 7('82), S('83) = LU5 305 CFI
VIN 7('83), G('84-86) = L69 305 HO 4-bbl
Old Feb 3, 2009 | 09:35 AM
Car: Trans Am
Engine: 5.0L 305
That doesn't necessarily mean it's an HO model. Take a look at your VIN to determine if it is or not. My 84 TA came with the functional cowl but it is not an HO according to the VIN.
Old Feb 3, 2009 | 09:39 AM
blg0720's Avatar
Car: 88 GTA
Engine: 305 V8 LB9
Yeah, mine is an H, which means it was the LG4 305 4-bbl. Good to know. Since the original setup was removed, I've never been really sure what it was except that it WAS the V8.
Old Feb 3, 2009 | 11:24 AM
ndamron's Avatar
Car: 82 Trans-Am / 83 Trans-Am
Engine: Major Mod SBC / Minor Mod SBC
Transmission: Major Overhaul 700R4 / Stock 700R4
Axle/Gears: None!!! / 3.73 posi disc...soon
I actually am looking for some of the under the hood induction pieces for either the carb or CFI models. How much for the under the hood plastic pieces shipped to waukesha, WI 53186
Nick
Old Feb 4, 2009 | 07:18 PM
TylerP's Avatar
Thanks for the tip. Dont have a pic of this by chance do ya?
Old Feb 4, 2009 | 07:26 PM
Dens71TA's Avatar
See attached pic.
Old Feb 4, 2009 | 08:44 PM
TylerP's Avatar
Thank you for that photo!
Old Mar 25, 2010 | 08:12 PM
jbucago's Avatar
Car: Black 1989 Formula Firebird
Engine: 5.0 TBI soon to be LT1
Transmission: 700r4 soon to be T56
So is this Power Bulge system worth anything these days???
Old Mar 26, 2010 | 04:04 PM
Dens71TA's Avatar
You could probably get $40-50 if you find somebody that needs it.
Old Mar 26, 2010 | 09:34 PM
Car: 84 trans am
Engine: 305 5.0L HO
Transmission: TH350
sorry I didn't get back with a pic.
I would say it's only worth keeping if you insist on staying completely stock.
Personally...I'm getting rid of mines and getting the GTA hood.
Old Mar 28, 2010 | 06:24 AM
jbucago's Avatar
I wonder who needs one... because i have like 3 that work!
Old Mar 28, 2010 | 09:06 AM
Car: 84 trans am
Engine: 305 5.0L HO
Transmission: TH350
post it up in the classifieds section.
that's where it's likely to get most attention.
In my opinion, it's more so the power bulge hood that attracts most people rather than the actual ram air concept...they want that KITT look I guess.
I can't wait to get rid of mine.
Apparently it's a hard come by hood these days and people are looking for them.
As far as the ram air setup....not sure how sought after it is. I think it only works for carb and TBI motors but I might be wrong on that.
Good luck
Old Apr 13, 2010 | 04:44 PM
SolarGoldRaptor's Avatar
Car: 1984 Pontiac Firebird Trans Am
Engine: V8 5.0L HO (L69)
Transmission: B&W T5
Axle/Gears: 3.73 limited slip
Good luck
They will surely be worth something in the future, they're just not much sought after yet. Those cars aren't old enough to be restored to their original form unlike 2nd Gens. They're hard to find though, so unless you really need the room, keep it aside.
I recently scored a very nice air induction scoop for $16 on eBay...and the complete air cleaner for $40, it just needs a respray. Only the lid is specific, the base and all the surrounding stuff are generic.
Even if it's not plugged, I think it's good to keep it mounted. If you remove it the rain will drip in the engine bay. The block off plate looks wrong in my opinion.
Old Jan 29, 2011 | 01:13 PM
graywolfman's Avatar
Car: 1983 Pontiac Firebird
Engine: LG4 305cid 4BBL E4ME Quadrajet
Any of you guys still have the parts and/or wiring information? I just had to replace my hood and the only one I could find has the hood trim piece, induction box and wiring missing. Any specific information, or if anyone is selling this stuff would be greatly appreciated! Let me know, thanks!
Old Jan 29, 2011 | 02:03 PM
Car: Trans Am
Engine: 5.0L 305
I still have everything that I removed from my car but I'm not quite willing to part with it yet as it might come in handy later, sorry. My TA is currently buried in snow but I can eventually get some pictures if you need to see where the wire hooks up, etc. I left the wiring in place and just removed all of the ducting since it caused issues when I changed to a holley carb a while back. If I remember correctly it was just one wire that runs up the hood to the solenoid to open up the cowl.
Now that I'm thinking about it, I don't like that the cowl is just wide open letting all the rain/snow find its way into the engine bay. Might have to set aside some time to make something that blocks off that opening but can open/shut using a solenoid like the old setup did.
Old Jan 29, 2011 | 02:06 PM
Alrighty, no problem. I just need to know where the wire plugs into that comes off the air box solenoid. I know one is a ground wire, but the other I just need to figure out where to plug it in at. That info alone would help loads!
Old Feb 2, 2011 | 05:54 AM
There should be a vertical connector on the relays tray on the firewall.
Old Mar 14, 2011 | 04:43 AM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
does any one have a CFI cowl unit for sale i need to repair mine
Old Mar 14, 2011 | 01:07 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Performance wise, its not worth alot. It also doesn't really have alot of 'cool factor' so its not worth much that way either.
That said, if you have a complete system in decent shape, it might be worth holding onto. Alot of the top model early 3rdgen cars, like the Z28 and TransAm, are starting to come up in value a little bit and are slowly starting to become restoration projects for alot of people. Parts like this in decent shape, would be worth holding onto for awhile, as they could be worth something to a restorer in the future.
Old Mar 18, 2011 | 02:49 PM
GICATA's Avatar
Car: '83 WS6 T/A 65,000 miles
Engine: 5.0L vin H stock, 406SBC right now
Axle/Gears: Corp. 3.73
I know this is an old thread, but what the heck.....
When mine was still functional it would suck water beads off the back of the hood when the engine was running wot and higher rpm. Yes there is a drain on the unit for the water, but that proves it is functional. How much it really adds to power I don't know, but I always thought it was cool to have "fresh air" to the carb.
I have since removed and stored the components away as it wont fit with a hi-rise style intake and Holley.
Old Mar 27, 2011 | 05:43 PM
oamhmad's Avatar
Car: 84 Trans AM
Engine: Goodwrench 350 Crate motor
To any one thinking of getting one of these cowl induction setups, be very careful, it cost me an engine.
Mine would let water drip into the engine through the carb and then one day during a heavy rain storm I started it up and the motor hydro locked catastrophically.
I'm still not sure how it let water in as everything was factory stock and I even had the flapper wired shut to prevent this very issue. I suspect the gasket around the scoop piece that bolts on top of the hood rotted away and let water drip into the whole system.
You've been warned! check for water on to and inside the air cleaner if you have this setup.
Old Jul 5, 2013 | 03:08 PM
colby91's Avatar
Car: 1983 recaro trans am
Transmission: 5 speed
Axle/Gears: 10 bolt 3,73
i have a 1983 firebird ta recaro nd it has the ram air but i cnt find a full assembly for it i have all the parts but they dont work cn anyone help me
Old Jul 5, 2013 | 04:38 PM
KITT1983's Avatar
Do you have the crossfire injection?
Old Jun 20, 2014 | 09:11 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
I just took that assembly off my car. my flapper motor was wired to a toggle switch though not on a vacuum. It was functional though and i would part with it. The rubber on top the air cleaner and everything still in good shape.
Attached Thumbnails 82-84 trans am factory ram air set up-332222.jpg   82-84 trans am factory ram air set up-828384v8.jpg
Old Jan 29, 2015 | 07:47 PM
JLow 87's Avatar
Car: 87 Firebird Formula
Engine: 305 OHC Carburated
Transmission: RM400
Hey I need the plastic drip tray for that set up. Do you have it? Thx Joe. If you do I would like to buy it. That's the only piece I am missing.
Old Aug 21, 2018 | 03:17 AM
katrav8's Avatar
Car: 1982 trans am
Engine: 4bbl carb 305 v8
Transmission: 3 auto
Hello. This is my relay board setup. Car has been converted from crossfire to 4 barrel carb. Engine though remains the same LU5.
I recently bought vaccum line switch from a carb setup 1984 T/A.
Where in relay board i have to install vacc switch? This vacc switch has a stem on bottom to add vacc line?
See photos here...
https://imgur.com/a/KWEaubf
Old Nov 20, 2018 | 12:41 PM
JojoDacosta's Avatar
See photos here...
if you replace the stock intake, will the Edelbrock Proformer intake work? It's the height so it works right and no water in. I seen on Ebay they had that app will it fit? Seen a weiand 3000 intake. I tried both the stock Corvette intakes the L82 and the L48 it said they didn't work, but they look like a low profile intakes? I know you get into the RPM intake it's much higher and I dont think it will work? Any information would be helpful. Thanks.
Old Aug 7, 2019 | 12:20 PM
PMDJIM's Avatar
Car: 84 Trans Am
Engine: 5.0
Axle/Gears: 3:23
Bringing this back up.... Does anyone have a photo of a low mileage original under hood insulator for this set up. Repop insulators are not cut out for this. So I am guessing I will need to fabricate the replacement.
Old Dec 8, 2020 | 09:50 PM
Brian Laycox's Avatar
Jeff
Jeff, I know its been 11 years since you wrote this post, but I just started looking for these parts and thought I would reach out to see if you still had anything left. At the very least, I need the air cleaner cover with the silicone squish gasket. What do you have, if anything? Thanks -Brian
Old Dec 25, 2020 | 11:52 AM
Cbr600elevator's Avatar
I'm looking for the air cleaner lid for the 82-84 carb air induction setup if anyone has one please let me know
Old Dec 25, 2020 | 11:54 AM
I'm looking for the 82-84 air cleaner lid for the carb air induction setup. Please let me know if anyone has one. Thanks
Old Dec 25, 2020 | 12:14 PM
I recently won one in an ebay auction bid. Its still in transit since 3 weeks ago. The seller shipped it by US Mail and Im starting to think its lost. There WAS 1 other intake for sale on ebay. It was fully refurbished and it didn't have the rubber seal that seals the hood. It was a toss up. I bought the uglier one which was cheaper, knowing I could repaint the lid myself. The picture i attached to this is the one I let go. Looks like someone bought it pretty quick. If I see another one I'll shoot you a message with the link to it. In the meantime find and join FIREBIRDS UNLIMITED group on Facebook. Its my own group based in Northern Illinois. If ya want
Old Dec 25, 2020 | 12:51 PM
  #42
Thanks Brian
Old May 3, 2022 | 08:54 AM
  #43
Jgregory0227's Avatar
What I wanna know is does the air induction on the 82-84 trans ams have any kind of water drainage if water is to get in them?
Old May 3, 2022 | 09:09 AM
  #44
Hello. Yes they have a drainage hole. Any water goes down into a small channel inside the unit and is dripped out on the side. I have a complete set to sell if anybody is shopping for it. The air cleaner with round rubber seal, and the cowl intake that bolts to the hood. I bought it in my previous post and never used it. Now it just sits in a spare room doing nothing for anyone, so I think I'm going to sell it. Everything works on it, even the actuator. You'd need to get the relay for it to make the actuator work, or I've seen people hook it up to a toggle switch, or they just leave it wide open. A toggle would be real easy instead of finding a relay to hook up to the throttle position sensor. Back in the day it would open automatically when you floored the gas pedal, but that took more components to make it work.
Old Aug 17, 2022 | 10:46 PM
  #45
Tommy320's Avatar
Car: 1987 Firebird Formula
Engine: 5.0
Hello... I am one of those guys looking for the functioning 82 to 84 carb cowl intake setup. Anyone willing to part with theirs? I found a working actuator and housing, just need the air cleaner box and seal
Old Sep 5, 2022 | 10:09 PM
  #46
1983LU5TA's Avatar
Car: 1983 LU5 Trans Am, 1967 Chevelle
Engine: LU5, LSx
Transmission: 700R4, 4L60E
Axle/Gears: 3.73, 3.73
The air induction unit used on 83-84 LG4 and L69 cars is not operated by the TPS. It is operated by the oil pressure sending unit, through a cold feed switch, and through a manifold vacuum switch that closes when manifold vacuum drops. The 82-83 LU5 cars were operated by the 5055/6026 ECM.
Old Nov 25, 2022 | 12:46 AM
  #47
mikelstudy_1's Avatar
Marc Webber
Jan 29, 2019 03:54 PM
cyberleader
Sep 23, 2009 07:20 AM
redline_racing
Fabrication
Aug 1, 2008 03:27 PM
chymos
Mar 6, 2003 08:18 PM
gruveb
Feb 22, 2001 11:40 AM
