Anyone run a single plane manifold on a 350 and had fab up an EGR?
Old Feb 23, 2009 | 10:51 PM
R.O.B.'s Avatar
Looking to build up a 350 or 383 and convert to a carb'd setup, and would like to have the RPM's in the higher range, so I'd be needing a single plane manifold. Yet I still have emissions to worry about, so I also still need the EGR valve. Has anyone worked around this issue?
Old Feb 24, 2009 | 12:38 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
It's not a normal thing to do because an engine that can properly use the powerband of a single plane typically isn't going to be sniffed. Or inspected.
A long time ago there was a plate you could put under the carb that had an externally-plumbed EGR valve attached to it. Haven't seen one in many, many years.
Old Feb 24, 2009 | 10:42 PM
SDIF's Avatar
Car: 91 Z/28, 89 RS Race Car
Engine: 305 stock / ZZ4 AFR 195 9.7:1
Transmission: T5 / t10 / Jerico
Axle/Gears: 10blt w 3.42, 9 in w /3.80 DL
Re: Anyone run a single plane manifold on a 350 and had fab up an EGR?
I am not trying to be smart by this comment.
"Does it have to actually work or do you have to have one for a visual inspection"
We do not have those inspections here in SC so I do not know. I have heard of those in GA only having to have the "items" to pass a visual.
Old Feb 24, 2009 | 10:51 PM
R.O.B.'s Avatar
I don't know what they will want, so I'd be better off with it working. I should also state, my goal is really to have an engine based around the AFR 195's, which has an operating range of 2000-6500. I'd like to find an EGR manifold to work with this, or, like I'm guessing at, use a single plane to do the job, with an external EGR.
Old Feb 24, 2009 | 10:56 PM
SDIF's Avatar
Performer RPM works well with that combo. I have tried both and have the rpm on now. It may be eaiser to fab a piece for this intake.
Old Feb 25, 2009 | 11:14 AM
R.O.B.'s Avatar
The Performer RPM would be perfect in the range, yet doesn't have the EGR. The Performer does, but its idle-5500rpm's.
Old Feb 25, 2009 | 01:22 PM
five7kid's Avatar
You're basically stuck with no EGR or an intake that doesn't quite match the cam's powerband. If inspection isn't an issue, i.e., they just sniff the exhaust, a cam like the ZZ4 has enough overlap that EGR isn't needed to keep NOx down.
AFR 195's may be fine to 5500-6000 RPMs on a 383, while the 350 would want to spin higher.
You understand the only "legal" carb would be a computer controlled q-jet.
Old Feb 25, 2009 | 01:26 PM
five7kid's Avatar
http://store.summitracing.com/partde...0&autoview=sku
Advertised powerband idle to 6000 RPMs. With gasket matching and a little clean-up, it should support a 383 and the AFR 195's (although the 195's are probably still a little bigger than optimum).
Old Feb 25, 2009 | 02:14 PM
R.O.B.'s Avatar
Thanks for the tip and good advice five7kid! Hopefully, the non-computer controled carb wont be an issue. I'll find out after I try it.
Old Feb 25, 2009 | 07:09 PM
five7kid's Avatar
From what I've gathered hanging around here, the Holley probably will be a problem.
customblackbird
Aug 15, 2021 10:16 PM
ezobens
Aug 19, 2015 10:29 PM
st.evel07
Aug 13, 2015 06:15 PM
Jake_92RS
Aug 11, 2015 10:39 AM
camaroken83
Aug 10, 2015 11:35 AM
