305 tbi to carbed 383 stroker
Old 04-18-2009, 05:25 PM
Sean2857's Avatar
Engine: 383 stoker in progress
Transmission: Soon to be a TH400
just a quick question.. would i just need to add a fuel pressure regulator to drop the fuel pressure down for the carb or do i have to go all out and change the pump in the tank. the pump is only about a year old and i dont feel like dropping the tank again haha.
Old 04-18-2009, 07:04 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
You need a return-style regulator such as the Mallory 4309.
The standard $25 dead-head reg will kill the pump.
Old 04-18-2009, 07:16 PM
Sean2857's Avatar
Re: 305 tbi to carbed 383 stroker
okay so i just need to get that regulator and hook the return line up to it? sounds easy enough :-D
Old 04-18-2009, 07:38 PM
buzzman1's Avatar
Car: 90 formula
Engine: 305 carb
Axle/Gears: auburn 3.73 posi
dorman sells lne kits to convert the stock lines to 3/8 compression fittings..the stock lines are a unique gm fitting.if you need pics let me know, you will also need to wire a 12v+ ignition on wire to the green/white wire to the fuel pump relay of it will shut off after 3 sec. just finished mine and glad to help with any other issues...good luck
Bizzman1
Old 04-18-2009, 08:48 PM
Sean2857's Avatar
do you have a part number for the dorman conversion?? pictures would help a lot also. :-D thank you for your help.
Old 04-19-2009, 01:24 AM
92RSStud's Avatar
Car: 1992 Rally Sport
Engine: 355CI
Axle/Gears: 10bolt stock gears
lol..i just sent you a message buzz man then read this... i also am interested in the part number, and any info on the wiring for the fuel pump relay. so i know i get it done right... i've got about a billion wires to sort though >.<
Old 04-19-2009, 11:07 AM
buzzman1's Avatar
Car: 90 formula
Engine: 305 carb
the dorman numbers are 800153 for the supply and i think 800151 for the return but i was able to use a piece of the old return line for that. thefuel pump will require a 12v+ ignition on power source wired to the green/white wire going into the fuel pump relay. cut this wire a few inches from the relay and connect it to the ignition on power supply and thats it.
hopefully pics will help...be patient as it took a lot of hours to get the conversion right.
good luck
Buzzman1
Attached Thumbnails 305 tbi to carbed 383 stroker-mallory4309-003.jpg   305 tbi to carbed 383 stroker-mallory4309-005.jpg   305 tbi to carbed 383 stroker-mallory4309-006.jpg
Old 04-21-2009, 12:18 AM
ziggy89's Avatar
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
i used the mallory afpr you can see in buzzmans pic
used the stock feed and return line there and it worked great
all i did and the 383 is runnin strong
Old 04-21-2009, 09:18 AM
buzzman1's Avatar
Car: 90 formula
Engine: 305 carb
yeah..I hate dropping the gas tank.
mine works great ...do you get a little flucuation in pressure like 5-6 or is yours steady?
Buzzman1
Old 04-21-2009, 09:53 AM
ziggy89's Avatar
Engine: 383
it bounces a little bit but not too bad
the bowls stay full so it didnt make it hard to tune or ne thing like that
Old 04-21-2009, 06:54 PM
scooby143's Avatar
Car: 89 c1500 truck
Engine: 383 stroker
Transmission: auto
Axle/Gears: not enough now
i havent wired my fuel pump like you say, is that why it will only run for a few seconds but never has any fuel pressure?
Old 04-21-2009, 07:25 PM
Sean2857's Avatar
sounds like you guys know what ur doin haha. i ordered the regulator and dorman parts today. they should be at the store tomorrow when i go into work :-D
Old 04-21-2009, 07:58 PM
383fbod's Avatar
Car: 88 IROC-Z
Engine: 383
Axle/Gears: 4th gen 3.42posi
Buzzman1
try cutting an access pannel in the body above the fuel pickups. never drop the tank again
Old 04-22-2009, 09:47 PM
buzzman1's Avatar
Car: 90 formula
Engine: 305 carb
yes to the fuel pressure , if you don't wire the green/white wire to 12v+ ignition on the pump will only run for like 3 secs and then no pressure.
Buzzman1
Old 04-22-2009, 10:07 PM
ziggy89's Avatar
Engine: 383
you can do it the way i tried to
i was gunna use the relay like a primer witch is the only time the compouter actully runs the fuel pump
then i was goin off the oil pump switch so that any time it had more than 5 psi it would run the fuel pump like it would stock
only problem there was i must have cooked the oil pressure switch cause after breakin in the cam it stated to stall on me so i just wired it up like stated above
some food for thought if interested
zig
pimp2303
07-27-2017 02:03 PM
mhatfield 14
10-24-2015 07:48 AM
Reddeath210
10-06-2015 08:20 AM
Jae992
08-27-2015 09:07 AM
Quick Reply: 305 tbi to carbed 383 stroker
