Converting to Carb - Holley 650 DP 6498?
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
I can get this carb for 60 bucks shipped to my house but it may need rebuild. Is this a decent carb to start off with? I have a post 87 350 block so I will be getting the 2704 performer intake and dizzy. I just want something that will give me a little power and easy to tune etc. I am just looking to get into the low 13's. Nothing too big.
I guess it came out of a 1967-71 Plymouth?
Cross referencing says that it's the same as the 4165 holley? http://www.summitracing.com/parts/AE...n/?prefilter=0
Engine: 355/350
Engine: 355/350
Car: 86 T/A
Engine: 383
Axle/Gears: 3.27 9 bolt
Re: Converting to Carb - Holley 650 DP 6498?
Not a bad deal but you will still probably have to drop another $50 on a rebuild kit for it.
The performer manifold's operating range is idle-5500rpm
the rpm air gap is 1500-6500rpm
the air gap has a gap under the runners for air to flow under and allow for cooler air or something like that. I would guess that they have a little longer runner.
Engine: 355/350
I'm still learning bare with me :P
Car: 86 T/A
Engine: 383
Yea the performer would be fine for ya.
However the 4165 is a spreadbore and single inlet. :\
Engine: 355/350
Car: 86 T/A
Engine: 383
Square bore- The 4 barrel carb's front and rear throttle plates are the same size.
Spread bore- The carb's rear throttle plates are larger diameter (like a GM Quadrajet or Chrysler Thermoquad)
Engine: 355/350
If so in what way?
Would I have a pretty decent combo with the performer and this Holley 650 DP?
Car: 86 T/A
Engine: 383
No sorry its late here I just noticed the 4165 was spread bore.
The rpm air gap is for a square bore. Personally if it was me I would try to find a holley carb 4777 (650cfm double pumper) along with the 7501 edelbrock.
Engine: 355/350
Thanks for all your help though! Will be bookmarking this for future reference :P
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
rule of thumb (though not set in stone) auto trans - vac. sec standard = D.P.
you also have to figure in driving habits. if you have a heavy foot, you better have gas $$$ if you get a D. P.!
BlackphantomZ28
Aug 22, 2015 01:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
86IROC112
Aug 17, 2015 02:00 PM
