Carb Advice
Old Jul 18, 2010 | 02:47 PM
CameronLambert's Avatar
Carb Advice
Looking for recomendations on a carb looking for best performance but also drivability is also important. My car has a 383 stroker with 6" rods World sportsman 2 heads a
Lunati Voodoo 60112
•Advertised Duration (Int/Exh): 282/290
•Duration @ .050 (Int/Exh): 231/239
•Gross Valve Lift (Int/Exh): .535/.550
•LSA/ICL: 110/106
•Valve Lash (Int/Exh): Hyd/Hyd
•RPM Range: 2400-6200
A weind intake
Manual T5 tranny
and 4:11 gears future plans to go back to 3:73
I was looking at the holley street avenger 670 but im open to any sugestions.
Thanks alot
any other info needed just ask.
Old Jul 18, 2010 | 03:32 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Since you have a T5 transmission, you'd be better served with a mechanical secondary carb.
Which is more important to you, power, or driveability? If the former, get a 750. If the latter, get a 650.
Neither one would be "bad" for the other, though.
Which Weiand intake? Stealth?
Old Jul 18, 2010 | 04:13 PM
Re: Carb Advice
its actually a older model its a weiand action plus 8004
performance is more imprtant. So a 750 DP what model for easiest tuning
Old Jul 18, 2010 | 04:46 PM
five7kid's Avatar
I know they say the Action + is good to 6000 RPMs, but that's a stretch. And, your cam powerband goes higher, so it would be better to go with the Stealth if performance is your priority.
"Easiest tuning" - not sure how to answer that. A "regular" 0-4779 would have the jet, power valve, squirter, and pump cam tuning available, while an Ultra DP model would add billet metering blocks (0-76750BK for black metering blocks - not sure if they have screw-in restrictors), and comes with an electric choke.
If you want more tuning capability than that, you'll have to give up choke, or go with a Demon.
Old Jul 18, 2010 | 04:56 PM
Re: Carb Advice
Great thanks for the advice, i will look in to another intake manifold when i start doing the work is there any other manifold you would recommend over the stealth?
Thanks for your help
Re: Carb Advice
room is also no issue i have a 4" cowl hood
Old Jul 18, 2010 | 04:57 PM
Zerocyde's Avatar
Car: 88 Camaro
Engine: 416 Stroker LS
Transmission: Magnum F
Axle/Gears: 4.11
Re: Carb Advice
Can you explain to me the correlation between your transmission type and your secondary type? Why would mechanical secondary be better for a T5? Isn't mechanical secondary better in general? What about on a T56?
Old Jul 18, 2010 | 04:59 PM
Re: Carb Advice
Mechanical is generaly better for a manual transmission. T5 T56 same thing
Old Jul 18, 2010 | 06:01 PM
five7kid's Avatar
Cameron, either the Stealth, or a Performer RPM.
cyde, I prefer mechanical secondaries regardless. But, with a T5, you can get into weird situations between gears with the secondaries staying open even after you let off the throttle, causing the engine speed to flash. If you have a rev limiter, no problem, but then you'll be banging the rev limiter. And, T5's don't respond well to "speed shifting".
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
makaveli09
Sep 15, 2015 10:43 AM
Wylecoyote08
Sep 8, 2015 08:26 AM
rjcme
Sep 5, 2015 01:23 PM
mrdevontay
Sep 2, 2015 08:04 PM
