355 dont like the cold
Car: 92camaro,86 camaro
Engine: 355
hope this is the right place to post this. well now my problem, i just got done putting a 355 carb engine in my car and now that its cold it dont want to start at all and when it does i have to keep pumping the gas pedal till it worms up or it will die what can i do to fix it?
Car: 1990 camaro RS
Engine: 305 TBI
Re: 355 dont like the cold
Is the timming right? is there a vacuum leak? heat riser? do you pump it twice to set the choke? is the choke not set up on your carb right?
Engine: 355
time is set at 8 cuz thats what my cam calls for, no vac leaks engine is fresh rebuild and when the car starts i have to keep pumping the gas till it worms up i dont have a choke
Car: 1990 IROC
Engine: Rebuilt L98 with H/C/I/Carb
Transmission: TH350 with ATI Treemaster
Axle/Gears: 7.5 with 4.10's
bump up the base timing a few degrees...do you have vacuum advance hooked up? Without a choke, it may stumble and idle rough, but it shouldn't be too bad.
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Car: 92rs
Transmission: 350
Axle/Gears: 3.73/Moser 12bolt
90 Camaro is correct,
with no choke it probably will run rough when cold.
I have a Holley 650DP no choke and it stalls at least once if it's real cold out.
I just got to keep it running till she warms up and it runs great.
Shouldn't take long to warm it up and smooth out.
Car: 1984 Trans Am
My 67 Camaro has a Holley 650 with no choke. With winters in Oklahoma when it was my daily driver I would have to start it and hold the throttle to 2500 for 2-3 minutes until it would idle on its own. Once that happened it would run fine. Never could I just start it cold and go.
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
ive run sever carbs with no chokes here when its cold out.pump it 2 times.fire it up.feather the gas a lil bit and hold it around 1500 rpms for a couple of minutes....then i let the car warm up a few more before i take off......no issues........
Car: 86 Firebird
Engine: chevy 366ci
I love chokes! had several carbed vehicles whil i was a kid, and as a result learned to rebuild carbs lol. There has got to be a way to set your choke prior to buying another. missing linkage or set screws are easliy replaced at your local pull-ur-part. or if your equiped with a electric choke, check your wiring and see if everything is right. Or if your like me and looking for an excuse to put money into your ride, a new carb is always a good investment!
Engine: 355
well takes me about 2 to 3 min of pumping the gas to get it to stay running but i guess i dont have to wirry about starting it anymore sence car is put up for winter thanks for all the help by the way i do have the cav ad hood up i might bump the timing up when the snow goes away and i start driving the car
darwinprice
17
Oct 11, 2015 11:51 PM
