Buying a carburetor
Old Jun 21, 2011 | 11:26 PM
sabresfan's Avatar
Car: Looking for a new thirdgen
Engine: hopefully a 5.7L 350
Buying a carburetor
I am looking into getting a new carburetor within the next month or two because i was told the one i have on the car now is pretty crappy. not to mention the floats are bad and the fuel mixture is off.
whats a good brand to get?
and where should i start looking? craigslist or possibly a junkyard?
Old Jun 22, 2011 | 12:11 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Buying a carburetor
What do you have now?
Old Jun 22, 2011 | 08:15 AM
sabresfan's Avatar
its a carter i believe
Old Jun 22, 2011 | 11:59 AM
jt1562000's Avatar
Car: '88 IROC-Z
Engine: 383 Stroker
Edelbrock makes street friendly carbs that are great if you want to tune it once and leave it. They dont make the most power, but they are simple and get decent fuel economy.
Holly carbs make more power but require more tuning. They are great if you understand how they work and like to tinker with them to get the best results.
I am currently running an edelbrock and am happy with it. It works well and doesnt cause me many headaches. I ran a holly double pumper for years and it performed very well but was more time consuming to keep adjusted.
There are also many other carb makers that fall on both ends of the scale, and can be a better choice depending on how you use the car and the altitude/heat of where you are.
If you can give us a little more info on your motor, upgrades, driving style, and use of the car we will be more able to point you in the right direction.
Old Jun 22, 2011 | 12:06 PM
sabresfan's Avatar
i believe it is still the stock 305 motor. it has been rebuilt within the last five years.
i am using the car as a summer daily driver and im looking for something that will make the car run better along with decent fuel economy. edelbrock carbs sound like the way to go. i found this ad which is in my local area for a used edelbrock http://rochester.craigslist.org/pts/2427184056.html
let me know what you guys think
Old Jun 22, 2011 | 12:23 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If you have a Carter AFB, it's exactly the same as an Edelbrock.
Old Jun 22, 2011 | 05:45 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I'm sorry, but those two statements are such a load of bunk.
Except the part about Holleys making more power.
An Edelbrock doesn't stay any better in tune with changing conditions than a Holley.
You don't have to tinker any more with a Holley than you do an Edelbrock.
Old Jun 22, 2011 | 05:54 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
carbs are great if you want to tune it once and leave it. They are simple and get decent fuel economy.
carbs require tuning. They are great if you understand how they work and like to tinker with them to get the best results.
There, I fixed it.
Old Jun 23, 2011 | 09:01 AM
stroker_SS's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
These are reasons to rebuild a carb and tune it.
Snap a photo and post up, we'll id it for you.
Old Jun 23, 2011 | 10:05 AM
89camaro355's Avatar
Car: 89 camaro
Engine: 355 sbc
Transmission: th350
Axle/Gears: 4.56
Deffinatly go holley or edelbrock...Its not worth going cheap in the long run.
Old Jun 23, 2011 | 10:07 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
There are cheaper carbs than Edelbrock?
Old Jun 23, 2011 | 02:22 PM
KnightmareCS's Avatar
Car: 82,83,99 T/As
Engine: 350,350,383
Transmission: ST-10,700r4,4l60e
Axle/Gears: P-3.23,P-3.42?,P-4.10
ba-dump-tsssshhhhhhh
Old Jun 28, 2011 | 12:37 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Qjet for the WIN!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
sreZ28
Oct 22, 2015 08:21 AM
budowski
Carburetors
Oct 2, 2015 10:16 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
