Choke light on
Old Sep 7, 2012 | 06:21 PM
Shep5B's Avatar
Car: 1985 IROC-Z H.O. 4bbl
Engine: L69 Small-Block, 305
Transmission: Borg-Warner T5
Choke light on
(85 Iroc 5.0 ,4 barrel Carb/Rochester)
How yall doin..i got a problem with my carb, when i turm the key to run, the choke light comes on , and i can hear a clicking sound in the carb, where as it dosent stop,, now when i go to start it, i have to tap the pedal a couple times untill the engine turns on, but when it does it starts to slowly die untill it shuts off.. Please. If u do know on how i can fix this, let me know. Thanks
Old Sep 7, 2012 | 06:27 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Choke light on
What do your spark plugs look like and is your choke pull off working like it is suppose to?
Old Sep 7, 2012 | 06:32 PM
Shep5B's Avatar
Re: Choke light on
My spark plugs look fine..But what do u mean by choke pull over like how would i know if thats good..
Old Sep 7, 2012 | 06:42 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Choke light on
The choke light is supposed to be on when the engine is off. What happens to the light when the engine starts?
Old Sep 7, 2012 | 06:45 PM
Shep5B's Avatar
Re: Choke light on
U know what. Here. Am gonna upload a video on youtube and give you a link to how my carb is actin
Old Sep 7, 2012 | 07:03 PM
Shep5B's Avatar
Re: Choke light on
http://www.youtube.com/watch?v=KpDsx...ature=youtu.be
Old Sep 7, 2012 | 07:04 PM
Shep5B's Avatar
Re: Choke light on
Old Sep 7, 2012 | 07:12 PM
nhgator's Avatar
Car: 1985 T/A
Re: Choke light on
If the choke light stays on it can mean your alternater,of all things is going bad,not enough output to keep the choke coil hot or open or whatever it's supposed to be.
Old Sep 15, 2012 | 04:53 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Choke light on
Well, the carb clicks, it's supposed to do that. Means the Mixture control solenoid is working. Should click for 10-30 seconds or so before stopping. ALl carbs need to hae the pedal pumped a couple times before starting, unless youjust turned it off and turned it back on.
As for the slowly dying, can't say. Have you used the paperclip method to check if there are any codes?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
383cam
Sep 9, 2015 06:01 AM
TBRays98
Sep 6, 2015 05:05 PM
Jetmeck
Sep 4, 2015 12:29 AM
luvofjah
Sep 3, 2015 07:08 PM
