Return Line!!!!!!!!!
Old Apr 4, 2013 | 05:30 PM
mr z28's Avatar
Car: 74 Nova prostreet 87 Iroc Z28
Engine: 427 671 blower 350 Built
Transmission: 700R4 both
Axle/Gears: Dana 60 an a 323 posi.
Just got off the phone with Holley an they told me If I change to carberator I would need a 12-841 fuel regulator because it would take the pressure coming out of the tank 87 iroc 350 an that I would have to change the 5/16 return line to 3/8 same as the feed. Can anybody give me some feedback on this. Thanks.
Old Apr 4, 2013 | 07:24 PM
Restrorob's Avatar
Car: 88 GTA
Engine: Built 355 to install
Transmission: Built turbo 350
Re: Return Line!!!!!!!!!
Part of what they said it true, If using the in tank pump with a carb you should have a return style regulator. Most carbs run around 6 lbs pressure.
Changing the return line size depends, TBI pumps run 9-12 lbs pressure while MPI pumps run as high as 60 lbs. I'm run'n a TBI pump in my GMC with the stock 1/4" return line and it works just fine, If your run'n a MPI pump I'd try the 5/16" return first before changing it out for it may work fine as well.
I plan on doing the same fuel system with the gen 1 swap in my GTA.
There are cheaper return style regulators on the market than the one they mentioned......
Old Apr 5, 2013 | 11:36 AM
mr z28's Avatar
How would I change the 5/16 line to 3/8 on the pump they are telling me 3/8 for return to regulator 350 tpi to carb. 12-841 regulator Holley. not 5/16 Thanks Larry
Old Apr 5, 2013 | 12:06 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Pressure doesn't matter to the size of the return line, volume does. If 5/16" was good enough to handle the flow of a stock pump with FI, it's good enough to handle it with a carb.
Old Apr 5, 2013 | 12:40 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
I have had no problems running the stock 5/16 return line in my 92. I'm using the original V6 fuel pump and a return-style regulator to feed the Holley on my 350. I have the Mallory 4309 regulator and run right around 7 psi to the carb.
Old Apr 5, 2013 | 01:12 PM
MacBoy24's Avatar
Car: 92 Camaro
Engine: TBD
Where do you mount your fp gauge? Summit's listing says it doesn't have a gauge port...kinda odd.
Old Apr 5, 2013 | 01:19 PM
mr z28's Avatar
Re: Return Line Questions?????????
Sounds good to me I dont what they are talking about Holley an Mallory said the same to use 3/8 for return.Just one more question can I use Russuel hard line tube fittings to hook up my lines to use braided lines or could I use rubber hose an clamps an do they have to be fuel inj. hose because of the pressure coming out of the tank.Thanks Again Larry.
Old Apr 5, 2013 | 01:29 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Pressure coming out of the pump won't be any higher than the regulator pressure. Braided lines and AN fittings are nice if they're in your budget.
Old Apr 5, 2013 | 01:50 PM
mr z28's Avatar
So in other words I dont have to touch the pump in the tank at all . Just hook up a regulator an lines an a relay an thats all correct? If the car sits for a couple monts you wouldnt need nothing to prime it right? Thank You Larry.
Old Apr 5, 2013 | 03:34 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Fuel should stay in the bowls. The electric pump should fill empty bowls in just a couple seconds if they are empty.
Old Apr 5, 2013 | 04:22 PM
Restrorob's Avatar
Car: 88 GTA
With any one of these that suits your choice of plumbing; http://www.summitracing.com/search?k...0fitting&dds=1
Old Apr 5, 2013 | 09:13 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
I mounted my gauge right at the carb. I just used a brass T plumbing fitting. The line comes into the 'bottom' of the T, one side of the 'crossbar' of the goes into the carb, the other goes into my gauge. The Mallory gauge I have also has 4 outlets, so I could have just screwed the gauge into one of those, but I wanted it right at the carb.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
R13_Braz
Sep 18, 2015 05:00 PM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
TBRays98
Sep 6, 2015 05:05 PM
