TBI to Carb
Old Mar 2, 2015 | 10:38 AM
DARKmj16's Avatar
Car: 92 25th anv camaro rs
Engine: 305 tbi
Axle/Gears: 3.08s non posi
TBI to Carb
ok first off i know i saw the article saying what i need and how to switch tbi to carb but i cant find it this time, probably wrong keywords or something. anywas.
i have a 92 camaro witht he 305 tbi and i want to switch it to carb. nothing fancy just carb. i guess i need a new intake and a dist thats vaccum controlled and ofc a carb correct?. anything else, for example what about the computer?
after i get my part list im going to a pick n pull, so which vehicles would be idea to grab said parts from? like i said i dont want nothing fancy. just need this motor to last till i get everything for my swap. a friend is going to pull this motor and do a cheap rebuild/reseal.
Old Mar 2, 2015 | 11:20 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: TBI to Carb
Not sure why you want to switch unless something is catastrophically wrong. The TBI is going to be more reliable, get better MPG and make equivlent HP. You're not gaining anything by going to carb.
Also, do you need emissions where you are? If you do, you cannot do the swap and pass.
That said, you need an older vacuum run Distributor, and a vacuum carb. I recommend Qjet, but others like Hollys and Edelbrocks. YOu will also need a way to control the lockup on your torque converter. TCI makes a decent controller for around $75.00.
As for electrical..
disconnect your sensors including 02, leave your tach hooked up but you really don't need anything else. Tuck the harness inside the fender for later if you ever want to swap back. It's pretty strait forward.
Old Mar 2, 2015 | 11:47 AM
DARKmj16's Avatar
Engine: 305 tbi
Re: TBI to Carb
ya there is something wrong with the car. theres always something. i have a grimling in the tbi system and im done replacing and fixing things so im going to the simple easy fix way. im probably only putting a 2barrel or small 4 barrel. its a factory 305 lol. plus its always running rich for some reason and im just done with this tbi system for now. i have a t-5 so looks like i save 75 there. and no i dont need emissions.
so old 305s... like 80s and below so have the parts? o and i know i need a fuel pressure regulator.
Old Mar 2, 2015 | 12:49 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Re: TBI to Carb
You will need to run a Mallory 4309 Fuel Pressure regulator with the carb. no more than 7Psi. Probably closer to 6. Leave your pump in your tank and make sure you don't cut the wiring for it. Make sure you hook up the return line, you will need it to keep the pump cool.
1992 and below 305 parts are nearly all the same. I'd get a 600cfm carb and Edelbrock performer intake. $150 or so for the intake and if you rebuild it yourself, you can find a cheap 600cfm carb for it. they're about $300 new.
Old Mar 2, 2015 | 04:46 PM
DARKmj16's Avatar
Engine: 305 tbi
Re: TBI to Carb
i was thinking of pulling the carb/intake/dist from the same 305. ofc rebuild the carb but again i dont need anything fancy since its a factory motor. and im trying not to bust my tran open lol. i realize a factory intake will choke the motor sum but i do have factory heads and what not. plus my swap is to a ls1/t56.
Old Mar 2, 2015 | 05:20 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Re: TBI to Carb
the issues with your factory intake, is I don't believe it has the 4 port opening or proper dual plane opening to run a 4bbl carb.
You should be able to pick up a decent dual plane carbed intake in a wrecker yard. Any Chevy 305 from 82-87 that had a carb, which is a lot of cars, would have it. You just need to pull it.
your current heads will work fine for the swap.
Old Mar 2, 2015 | 07:32 PM
DARKmj16's Avatar
Engine: 305 tbi
Re: TBI to Carb
no its a 2 barrel tbi. and ya thats what i was talking about is grabbing the intake/carb/dist from a pick n pull place lol. 82-87 hmm now to just tell the difference in a 305 and 350 id be sat haha
Old Mar 2, 2015 | 07:56 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Re: TBI to Carb
Don't worry about the difference between a 305 and 350 in stock form. Not enough of a difference to matter.
Old Mar 2, 2015 | 09:01 PM
sgp0511's Avatar
Car: 1988 Firebird
Re: TBI to Carb
just watch the middle intake bolt hole angles
Old Mar 4, 2015 | 11:29 AM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
Re: TBI to Carb
have to get the carb and hei from 70s ones, 80 are computer controlled. have to wire the fuel relay to a switch or so it comes on with the key.
Old Mar 5, 2015 | 12:12 PM
sootie007's Avatar
Car: 91 RS VERT
Engine: 305 9.67 2.02 58 cc 282 480 108 LC
Axle/Gears: 4.11 POSI
Re: TBI to Carb
https://www.thirdgen.org/forums/carb...s-305-tbi.html
My swap with every p/n I used
Old Mar 5, 2015 | 01:47 PM
DARKmj16's Avatar
Engine: 305 tbi
Re: TBI to Carb
thank you
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Wylecoyote08
Sep 8, 2015 08:26 AM
rjcme
Sep 5, 2015 01:23 PM
Billy Decker
Sep 4, 2015 03:46 PM
