No Start
Car: 1990 RS, 2002 Chev Silverado
No Start
My car has been running and starting fine. Today it will not start. There was a mouse under the hood. What wire would he have chewed. I can hear fuel pump run so think that isn't problem.
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: No Start
You need to be a little more descriptive in how it's not starting.
Does anything happen when you turn the key to the start position? Does the engine crank but not start?
Re: No Start
It cranks fine and I have tries pouring fuel into carb and nothing. There have been mice under hood for a couple days. How can I check spark? Fuel pump runs but don't know how to check pressure.
Transmission: 4L80E/4L80E
Re: No Start
VATS disables the starter.
Has your car been converted from TBI to carburetor?
Re: No Start
I have an 89 Camaro, new starter, new battery, no click, nothing. I even ran a wire from the activation bolt on the starter to the battery, nothing
mdtoren
Apr 12, 2016 09:22 PM
mthibode
Apr 12, 2016 07:04 AM
