Help Needed
Old May 4, 2018 | 10:13 PM
z28cop's Avatar
Car: 1985 IROC-Z
Engine: L69
Axle/Gears: 373 Limited Slip
Help Needed
Took carb apart to replace the gaskets... Im having two issues.. These rods were in the left and right bowls. Im assuming this is not correct?
Also the pin in the pic is keeping the top from setting flush on the body. Why wont it collapse? Any help would be appreciated. Pics of both issues.
Attached Thumbnails Help Needed-6792cb6f-a189-4980-9611   Help Needed-8f773cd9-6b36-4619-b67a   Help Needed-1c2a5c3e-fbf4-4586-b010   Help Needed-76fcf8c9-303a-4da0-889b
Old May 6, 2018 | 06:48 AM
DevX83z's Avatar
Car: 1983 z28 H.O.
Engine: L69
Re: Help Needed
Those tubes *should* be in the air horn (top part). Below is a pic of when I pulled mine apart to clean. You can see the four tubes if you look at the part of the carb in the center of my pic. Looks like those are the outside most two. They should just press back in, light tap with wood or something to seat them but not bend or otherwise distort. The lever (looks like the TPS adjustment from your pic) getting in the way should be able to be held back with a machinist ruler, or putty knife, or anything else thin that you can slide out once you have the two parts aligned.
Old May 6, 2018 | 12:36 PM
z28cop's Avatar
Car: 1985 IROC-Z
Engine: L69
Re: Help Needed
Thanks so much!! Got it back together!
davidopliger
Feb 3, 2025 09:30 AM
bartstalder
Aug 20, 2011 04:11 PM
kahless
Northern California
Sep 26, 2008 08:17 AM
chuck6860
Jul 23, 2002 09:36 AM
badbird88
Sep 19, 2000 08:15 AM
