Is my carb stock?
Old Sep 8, 2020 | 06:13 PM
The Real Mr.Blu's Avatar
Car: 1986 Trans Am
Engine: 5.7L
Is my carb stock?
Finally got around to pulling off the carburetor on my engine only to realize that the rebuild kit I ordered does not work for the carburetor I pulled off. It's a 4bbl quadrajet 17083204 which as far as I can tell did not come on a trans am in the 1986 model year. Does anyone know what this came from? There is also an additional number under it 2252 FRB.
Old Sep 8, 2020 | 06:32 PM
Re: Is my carb stock?
3204 sounds like LG4 from 83. Not exactly stock but as close as it can possibly be.
A kit for the one will "work" on the other.
How does the kit you have "not work"?
Old Sep 8, 2020 | 06:42 PM
Car: 1986 Trans Am
Engine: 5.7L
My specific carb isn't listed under the applications for the rebuild kit I ordered. Do you think this affects my engine performance in any way?
Old Sep 8, 2020 | 08:05 PM
Not really. Those carbs are all so similar; the gaskets (rebuild kit) are all the same, their differences are in minute drillings of passages, choices of jets & rods, and other such things in which "rebuild" is not affected. Just like the same head gaskets and oil pan gasket "work" in a 165 HP 76 Impala 350 and a 70½ "LT-1" in a Z/28". Sometimes not even that: might on many cases just be a matter of paperwork, as in, government agency certification that has to be renewed however often, even if the underlying object is unchanged.
Old Sep 9, 2020 | 10:55 PM
Car: 1986 Trans Am
Engine: 5.7L
Ah ok I see. The kit included a list of carburetors that it is used to service and the carburetor on my car was not listed there. Regardless, I haven't broke the seal on the internal packaging yet so I think I will just return it to summit and order one for the carb I have. Thanks for replying!
Old Sep 9, 2020 | 11:52 PM
Camaro86IrocZ's Avatar
Car: '86 Iroc Z & '91 RS
Engine: 305 TPI & 305 Qjet - Future LC9
If you return that kit, get a good one from Cliff. - Give 'em a call with your carb number, https://cliffshighperformance.com/
Old Sep 10, 2020 | 06:23 PM
NoEmissions84TA's Avatar
I can say for sure that the 1708 3204 carb did come on my 84 LG4 305 TransAm.
Old Sep 10, 2020 | 06:53 PM
Zackly.
It's the same carb. For several years running. Even if whoever compiled whatever "list" left this one off.
IROC216
Carburetors
Oct 10, 2012 02:41 PM
blue birdy 87
Carburetors
Jul 19, 2012 06:01 PM
Feniks9174
Carburetors
Sep 19, 2007 09:46 AM
bolandmi
Carburetors
Jan 12, 2007 02:20 PM
loomdog32
Carburetors
Dec 31, 2001 07:23 PM
