Removing Choke Horn
Subscribe
Dec 9, 2000 | 12:30 PM
I hear it increases air flow into the carb. any one done this and have et or dyno results to back it up? it's a holley carb.
ICON Motorsports
1st & 3rd
Reply 0
Dec 9, 2000 | 04:22 PM
I have seen such data, and it definatly helped. I'll be damned if I can remember any numbers tho.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
Jesters's Page of Sick Pleasure
Florida Thirdgenners Message Board
ICON Motorsports
Reply 0
Dec 9, 2000 | 04:37 PM
Removing the choke horn definately helps especially if you have a drop base aircleaner.
1984 WS6 Trans Am Hartop
Former L69 Car under restoration
1984 WS6 Trans Am T-top car
4-bolt main 350, headers, Holley 650, T-5 and 3.23's.
Daily driver and restoration
Reply 0
Dec 9, 2000 | 04:48 PM
Stupid question...
What's a choke horn? The sort of vertical extension that the choke plate closes against? If that is what one is, how does removing it affect cold startups?
Reply 0
Dec 10, 2000 | 08:00 PM
If you have no choke cold start-ups suck and really cold start-ups really suck. The choke horn on a holley is the part that sticks up on the primaries, one without the choke horn has both the primaries and secondaries looking the same.
Reply 0
Dec 10, 2000 | 11:34 PM
84FTA is totally right, I am in the process of selling my holley because of this. It is one Bad ***** once it gets warmed up, but before then, it sucks. If it gets cold where you are at all, you will need a choke.
Black 89 IROC...Mods: 355, 10.5:1 comp, Big Solid Crower Cam, TFS heads, Victor Jr, Holley, and a 5 spd...
Reply 0
Dec 11, 2000 | 05:09 PM
Ede< i removed Mine On the Qjet i was using before, and I noticed a definte seat of the pants improvement.
AS for Cold starts, It just takes a little effort, Ive never had it Be a REal Ordeal.
it only gets like 40* here tho
60 Ranchero - Project ( Money Hole )
85 Z28 LG4 - Daily Driver
**Mods**
MSD Superconductors
14" Open Element
KYB all around
Reply 0
Dec 19, 2000 | 09:15 PM
Well... I can't give you dyno results, but I can give you G-tech results. When I first installed, and tuned the carb, my best g-tech time was a 13.15. I pulled the carb, took a cutter to the choke horn, smoothed the rough edges off, and broke out of the 13s.
91 Firebird Formula. Converted to carb. Holley 750. Forged Flat top pistons. 10.5 to 1 compression. ZZ-9 Cam. Ported L98 Heads.
175 shot NOS, 700r4 w/ 3000 rpm converter and 3.73s in the back. Headers w/ full dual exhaust. 27.5 inch McCrearys. (free slicks)
12.98 @ 106 Natural,
11.83 @ 113 NOS.
Reply 0
Dec 20, 2000 | 06:15 PM
thanks, i'm going to mill it off. cold starts isn't a problem, it'll never be drove in the cold.
ICON Motorsports
1st & 3rd
Reply 0
Subscribe
