My 1985 Qjet
My 1985 Qjet
My Qjet is having problems. Should i keep and rebuild, or but a new carb? If i buy new what do you suggest? My camaro is a 1985 Z28, 305 upgraded to 350. Everything else stock. Thanks
ok ive done this conversion so any questions you have email me at hotmail.com and ill answer them all first: lose the computer. put a vacuum advance hei distributor in along with a 600 edelbrock with a manual choke i say manual because its for max performance. any questions email me or post nother reply on this board
burnoutrpm@hotmail.com
1989 firebird formula
Mods: converted from T.B.I. to a carburator 305 to a 350. Flowmater exhaust,hedman shortie hedders,202 heads,350 horse cam,bored.40 over, Edlebrock torker2 intake.
Future mods 400 performer rpm intake (polished) and 600 edlebrock carb, comp roller cam, and way better heads. orpossibly a 383 stroker?
Just remember that if you need to pass emissions that doing the above computer-ditching exercise will make your car emissions illegal. If your state does a VISUAL underhood inspection for emissions equipment they will likely pick up on the non-stock carb and distributor and fail you. If you have no emissions or only need to pass a tailpipe sniffer then you'll be just fine.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Check the magazine articles for Steve Green's piece on Thirdgen Rebirth. He sent his carb & ECM to Jet Performance along with an answer sheet about his combination (he did a 383), and bolted it in. He later did ignition upgrades (MSD) to get out of it what it was capable of.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LB9 w/ZZ3 cam, TBD heads, exhaust, paint, etc.).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
this one is easy ditch the q-jet (if and onlyif you have the money!) i always suggest a edlebrock 600 man. choke it'll run like a whipped ape from the box enjoy!
Future mods performer rpm air gap intake (polished) and 600 edlebrock carb, comp roller cam, and way better headsa 400 defintely in the works!
as for emmisions i live in missouri! emmisions whats that?!! ha ha!! i'm only equipped to "make" smog and not prevent it.
as for what that other guy said suggestion, they'll make the q-jet run awesome but do you really need to re-finance you house for that?? a new 600 edlebrock is only 200$ not cheap but defintely less than a jet q-jet re-bulid!!!
I slapped a holley on my 78 firebird in the past but don't recall whether I did the throttle and trans linkage or the mechanic. Did you have to get any kind of adapter for the holley as far as the throttle and trans cables go?? Cheers
1984 Camaro Z-28 LG-4
Q-Jet, dual snorkel air intake, underdrive crank pulley, Hypertech Street chip, SLP y-pipe and 3" cat back with hi-flow converter, Edelbrock Performer intake,Accel ignition. Running better now.
Car: 1986 IROC
Engine: 305 going to 355
Thanks,
Mark
1986 IROC LG4 "Bone Stock" (for now)
Engine: LS1/LQ4
The article didn't mention cost - you'd have to call Jet. He did pass emissions on the first try, according to the 2nd article.
Hey 1985-Z28,
Can you tell me what color your Mixture Control Selonoid is, and roughly what shape. I got a "new" q-jet carb off an earlier application (81-85) and the plug dosnt match up very well with the selonoid connector. Im wondering if i could get a plug from an earlier application.
Thanks.
Thanks.
