what cfm should I get?
Old Jan 15, 2001 | 12:29 PM
camaro fanboy's Avatar
I'm gonna get a holley double pumper but I need a reccomendation. It's a 74 corvette 350, agressive cam, 13.5:1 compression and 400hp. It was used in truck pulls. I saw on another post that 600 would be enough for this engine size, but will it be enough for MY engine?
Old Jan 15, 2001 | 02:07 PM
Jester's Avatar
I'd say 700. maybe 750.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
Old Jan 15, 2001 | 06:37 PM
CamaroMike's Avatar
13.5 to 1 compression! HA! Good luck getting fuel for that thing.
84 Camaro ZZ4 with HOT cam. 1.88 60' (12.98 @ 105MPH E.T.)
Other Mods: You name it and I have probably changed it.
2001 Dodge Ram Quad Cab 5.9L 4*2
ASE Certified Auto Tech
LIVE AND DIE BY THE ALMIGHTY BOWTIE!
Old Jan 15, 2001 | 06:56 PM
GOLD85's Avatar
13.5 what the hell kind of pistions/ heads do you have. 650 cfm is more than enough with a singel plane. you can run about 700 cfm with a dual plane. its been my experance the singel plans like a little less cfm so that they are more responsive.
when the green flag drops the bull$hit stops
Curent: 350,performer RPM intake ,650dp, 700r4, headers, 3inch exhast
Spring 01: 406, Comp 282 solid cam, 2400 stall converter, every thing else the same.
Old Jan 16, 2001 | 12:58 AM
The pistons are forged trw domes. The heads are stock 74 corvette. I know I'm gonna have to run race gas. I read on the hotrod site that high compression engines run best with single plane intakes,a monster carb and large tube headers.
Old Jan 16, 2001 | 10:45 AM
Box of Rocks's Avatar
Fan,
It will not be nearly enough. The following formula comes directly from Vic Edelbrocks catalogue:
CFM requirement = cubic inch displacement X max RPM X volumetric efficiency(%) divided by 3456.
Now, what ALMOST NOBODY mentions is that a correction factor exists for single plane and dual plane manifolds. It is: for single plane multiply by 1.1 to 1.3
For dual plane multiply by 1.2 to 1.5
So, presuming you have 1.00 VE since you have 13 to 1 compression, and presuming you'll have a redline of 6,500 RPM, using a single plane manifold, it goes like this:
350 X 6,500 X 1.00 div. by 3456 = 658 CFM
658 X 1.2(avg.) = 790CFM.
I'd use a 750DP or 800DP.
BOR
Old Jan 16, 2001 | 08:45 PM
CamaroMike's Avatar
BOR, TELL ME MORE ABOUT THIS MAGIC CORRECTION FACTOR! I have never heard of such. Where did you find this data. Who can support your claim. If true this could shed light on the old carb size debate! Mentor me.
Old Jan 16, 2001 | 09:01 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Hmmm. From that formula for my new engine, my 850DP Speed Demon is near the bottom end of what I need. Looks like I'll have to start looking around for a 1150 dominator. Or maybe a couple of 650's mounted on a tunnel ram. Mmmmm.
Nothing like having a race engine. It's hard to over carb it. 2 fuel curcuits. Idle and WOT.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
454 Big Block almost ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Old Jan 18, 2001 | 12:58 AM
burnoutrpm's Avatar
id say for that hot of a engine a deeply jetted 750 or stock 800. you need lots of fuel for that compression! forget what the math geek says,do like the old hotrodders do just guess and work from there!
1989 firebird formula
Mods: converted from T.B.I. to a carburator 305 to a 350. Flowmater exhaust,hedman shortie hedders,202 heads,350 horse cam,bored.40 over, Edlebrock torker2 intake.
Future mods performer rpm air gap intake (polished) and 600 edlebrock carb, comp roller cam, and way better headsa 400 defintely in the works!
Old Jan 23, 2001 | 11:42 PM
Don Christensen's Avatar
Car: 1989 Formula - Red
Transmission: 700 R4
Axle/Gears: 3.73 Posi
I run an 11.5:1 406 Small Block in my 63 Nova, and it is very therapeutic with just a 750 Double Pumper. The car will lay rubber in all gears. Because of the overlap in the solid-roller cam, it does fine on Premium pump-gas.
For your set-up stick with a 700 and get an aftermarket mechanical fuel pump to keep it full. It sounds like a slick dual-purpose car.
PurelyPMD
May 5, 2016 04:57 PM
sreZ28
Oct 22, 2015 08:21 AM
randy210
Oct 15, 2015 03:43 PM
okfoz
Oct 13, 2015 02:19 PM
Dragonsys
Sep 25, 2015 03:51 PM
