Edelbrock carb question....
Old Feb 3, 2001 | 12:43 AM
PPonU4Me's Avatar
what vacuum side do you hook the vacuum advance of the dist. to? Does it need the Full time vacuum or the ported vacuum side?
Old Feb 3, 2001 | 12:48 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Normally the distributor is connected to ported vacuum.
Old Feb 3, 2001 | 01:25 AM
Fast-Formula's Avatar
I agree ported
Old Feb 3, 2001 | 07:24 AM
The ODB's Avatar
Most people I am close to do not run vacuum advance, but those who do prefer to connect direct to a manifold port. I have also done this in the past and just plug off the ports on the front of the carburetor.
Old Feb 6, 2001 | 08:49 AM
chris83z28's Avatar
It is the bottom left vac. port on the front of the carb.
1983 Camaro Z28
Goodwrench 350ci V8, Edelbrock TES Headers, Flowmaster Catback, MSD 6al and Blaster 2 coil, Edelbrock Performer intake, Edelbrock Performer 600cfm carb. T5, 373 rear, Eibach springs, Cervin Vega speakers, Rock. Fos. Sub, Pioneer CD,
email-chris4421@hotmail.com
"I used to be a Mustang Guy! I didn't know the power of the dark side!!"
Old Feb 6, 2001 | 11:26 AM
Racerwannabe's Avatar
IMO If you have a functioning EGR system use the ported vacuum, if you have no EGR use the manifold vacuum.
Also, If you are not running EGR you also will want to limit the total vacuum advance using the Crane adjustable kit. The other kits I've seen allow you to adjust the curve but not the total amount of advance.
Old Feb 7, 2001 | 03:15 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Where is the manifold vacuum port?
I have the Edelbrock 1406 Carb and Edelbrock 7101 Performer RPM intake.
Zepher
'86 Pontiac Trans Am WS6, LG4 305, 5 Speed, CF DF Clutch,
Edelbrock 1406 Carb, Edelbrock Performer RPM 7101 Intake Manifold.
Edelbrock Open Element Air Cleaner: Flowmaster Exhaust, 160* Thermostat,
Grant GT Steering Wheel, MSD HEI Coil, Taylor 8mm Wires, Leather 96 Camaro SS Seats,
Alpine CD+Changer,Alpine V12 Amps, Premier TS-1040C Subs, Polk Audio highs/mids.
Best ET: 14.94@91.67
High Speed Run: 157mph
WS6 Trans Am
Old Feb 7, 2001 | 03:43 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Ported: Passenger side front
Full-time: Driver side front
PCV: Center front
Brake Booster: Center rear
Old Feb 7, 2001 | 05:52 AM
The ODB's Avatar
manifold vacuum can either be from a port directily in a manifold runner, the rear brake-booster port on the Carb, or the front PCV port on the carb. Those are the best places.
The small ports on the front of the carb I do not recommend using for a couple of reasons.
Old Feb 10, 2001 | 12:40 AM
burnoutrpm's Avatar
if you want my opion and you prbably dont i use a edle600 1405# and i have tried both and the ported ran great yes, but, when i came up to stoplight it would idle fine then just idle really low like400 rpms but when i put it to full advance on the carb it slowed a bit but , idled fine at lights?? waz up with this picture?? the ported never worked for me!
1989 firebird formula
Mods: converted from T.B.I. to a carburator 305 to a 350. Flowmater exhaust,hedman shortie hedders,202 160 (882) heads,.447/.447 lift 222@.050 duration speed pro 327/350hp cam 350 .40 over (356) Edlebrock torker2 and a 600 edlebrock manual choke (1405)
Future mods performer rpm air gap intake (polished) comp roller cam, and way better headsa 400 defintely in the works!
codeysabatini
Nov 10, 2015 04:07 PM
sreZ28
Oct 22, 2015 08:21 AM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
Scorched1984
Sep 15, 2015 03:42 PM
WickedBowtie
Sep 11, 2015 11:24 PM
