Third Gen FBody <2500
Car: 85 Suburban
Transmission: TH400
I need a A fBody In clean shape for under 2500 So Load me up with replys and send pix to chrismurad at sbcglobal dot net
Car: 89 Camaro RS
Engine: 86 Monty 305 .030 over
You still looking? I have an 89 RS that has an 86 monty carlo 305 H.O. bored 30 over. Let me know because if so i can get scanned pics or when my mom lets me set up her digi cam i'll take pics. It needs some work, but the price is in the right range, if u want more info you can look in the for sale section or just post here and i'll post info
Muirner
Muirner
Want a title? Post!
Car: 83 Z28
Engine: 350/380
83 Z28
$7000.00 75K original miles new eng, trans have reciepts
must see have lots of photos located in Bloomington, IL
As it sits right now--------Engine Specs Built and Dyno Tested by MAS performance W6337 US Highway 10 Ellsworth,WI 54011 PH>715-273-5027 ads can be found in Super Chevy Mag.350/380hp Crate Motor Dyno Date 05-16-03 (sheets to new owner) Speed Pro Hypereutectic pistons 350/ 0.125 dome top 10.68:1Cast Steel Crank Bore 4.030 Stroke 3.480 Rod 5.700 (ground and polished and the oil holes are chamfered)Comp Cams/ cam, lifters, and valve springs.Cam 12-242-2 1600-5800rpmIntake 224/230 Adv/Dur. 268/280 Lift .477/.480New GM Vortec cylinder heads and New Edelbrock Air Gap Intake toped with a 750 Holly vacuum secondary carb, Fel-Pro gaskets, and Clevite Bearing. New tin and harmonic balancer with an HEI distributor.Transmission700R4 Built with large clutches and larger valve body, Stall Convertor 2400-2700 with a manuel overdrive lock-up switch on dash, B&M Megashifter w/ Reverse lock outExhaustHooker Headers 1 5/8 and Y-pipe no cat, to FlowMaster 3'' american thunder systemTiresBFG T/A Radials, Rear 255/60/15 Front 235/70/15 warranty/receipt to new owner tires have less than 1,000 miles on themthis vehicle also has Factory 4 Wheel Dics Brakes Good Stuff----- No Rust, No Door Sag, Solid Steering handles like new, Never smoked in and interior is great. Engine and Trans built and installed professionally at same time Vehicle Original Miles 75,000/ Miles on Engine and Trans 3500 to best on my knowledge, oil is changed two sometimes three times per season just because.Bad Stuff ---- center of dash is cracked, head liner is removed but will go with car ( I was going to have in replaced) windshield wipers don't work but motor is there( but never driven in rain) and vehicle is a summer month ride sorry no heat was taken out before I bought it.
I have lots of Photos but there to large to post on here.
Car: 2 Stangs, 2 Third Gens, AWD Talon
Engine: 302, 302, 305, was 327, 4G63
Transmission: T5, C4, T5, T5, 5 Speed
Axle/Gears: All Kinds.
You looking for anything inparticular? I have a 91 RS 3.1 V6 Auto, hardtop if interested. it's way <2500 too. Let me know if you're interested.
Lowell
Lowell
Car: 85 Suburban
Transmission: TH400
Looking good everybody keep em comming... Also if anyone is willing to trade you can see this post here
https://www.thirdgen.org/techbb2/sho...hreadid=293907
I hope the pics worked for you this time. If not, I have one more idea. LoL. I hate hotmail....But If you're interested in the car, I'll make you an offer you can't refuse
Car: 89 Camaro RS
slog u still lookin around, i just posted pictures of my camaro in my thread https://www.thirdgen.org/techbb2/sho...hreadid=278898
Muirner
Muirner
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
If you want to spend a little more, I am selling my 88 Formula 305 TPI 5 speed,
And my brother is considering selling his 96 Trans Am LT1 Auto with 3600 stall, heads, cam, etc....
His car is is with him in Independence, MO.
Orr89RocZ
Oct 7, 2015 12:47 PM
