What part is this?
Old May 9, 2004 | 09:53 PM
shipfitter_sjd's Avatar
Car: 1992 Camaro RS Convertible & 1983 P
Engine: 305 TBI & 305 4 BBL & 4.7 liter
Transmission: Auto & Auto & 5 Speed Manual
What part is this?
1992 Camaro RS convertible.
I noticed that when I lower my top into the well, parts of the top are being scraped and in some cases starting to rip.
There is a strip of serated metal covered with a black material that covers the sheet metal seams and is supposed to protect the top material. This goes from side to side in the well.
I apologize that I do not know the proper name for this item. Does anyone know what it is called? Does anyone know where to purchase a new replacement piece?
Thanks!
Steve
Old May 10, 2004 | 09:39 PM
Droptop_Z's Avatar
Car: 88z
Transmission: t-5
Can you get a picture of it?
Old May 10, 2004 | 09:52 PM
My description suxs!
Nahhh. I do not have a digital camera.
Reading back through my post, if I hadn't of written it I wouldn't even know what the hell I was talking about!
I will have to check around the web for more info.
Thanx,
Steve
Old May 11, 2004 | 01:05 PM
nikh23's Avatar
Car: 88 IROC Convertible
Transmission: Raptor 700
if you tell me how to take the picture i'd run to my driveway and take one for you. Just let me know if the tops houdl be up/down and at what location this piece is at. I'll just snap a bunch of pics and you can locate what piece you're talking about
Old May 11, 2004 | 02:24 PM
Cargasm's Avatar
I know exactly what you're talking about... I had the same problem with mine. I debated buying a new one.... but it seems that almost everything 3rdgen 'vert related is pretty pricey. Instead, I pulled it off, reversed it and remounted it (using 3m contact adhesive). No more snagging problem, and you can't even see where the serrated metal came through the rubber! Problem solved... (for now).
Old May 11, 2004 | 05:07 PM
Thanks nikh23!!
Just lift the back of the top up and then pop open the tonneau cover (or whatever you call it). If you look at the inside of the fender where the seam or lip is, then you will see a strip or bead of black material that is covering a serrated metal interior.
That is the piece that I want to know the name for and an out source for it.
Thanks!!
Steve
Old May 11, 2004 | 07:34 PM
Ovrclck350's Avatar
I know exactly what piece you're tlaking about too. If I get a chance I'll take a pic.
Old May 13, 2004 | 02:50 PM
nikh23's Avatar
is this the piece you were talking about?
Old May 13, 2004 | 03:43 PM
That Would Be It................
That is the piece.
Anyone got a name for it? Anyone ever have to replace it?
nikh23, thanks for taking the time to take the picture.....I appreciate it. Now, maybe my description will make more sense!!
Steve
Old May 13, 2004 | 10:45 PM
nikh23's Avatar
no problem, i jush wish i could help you on the description as well.
Old May 14, 2004 | 06:49 AM
Speedgraphic's Avatar
Car: '90 RS Vert
Engine: 305 TBI
Transmission: 700-R4
I just emailed you some pages from the camaro parts list. I hope it helps!
Speedy
Old May 15, 2004 | 04:20 PM
Thanks for the info!
Is that repair info from a collision shop manual? I am not sure if the piece that I am looking for is on those pages, but there is a wealth of info and part numbers that I need to check into.
Thanks again for your time and consideration.
Rock on!
Steve
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
