Camaro 'Verts are weak, creak a lot and underpowered?
Old Oct 20, 2004 | 03:44 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Transmission: T5 Manual
Let me start this off on the right foot. I have sold my beloved '86 IROC coupe and next year or at the latest the year after will want to buy an IROC or RS 'vert. Clearly I'm going to miss the ZZ4 when going to the standard 305, but performance isn't everything I'm more concerned about reports of audible creaks and groans as the chassis are so weak and doors not shutting etc.
Do sfc's and stb's really tighten the car up? I know it did to my coupe. Am I making the right choice going for a 'vert- I think they look stunning!! I will ideally want a stick shift. Very rare in the UK, but I want to get it right!
Any advice or tips appreciated.
Hope to be part of the clan soon- I miss my IROC already
Cheers,
Felix
Old Oct 20, 2004 | 08:38 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
aftermarket SFC's will deff help. and a STB wont hurt either.
if your really feeling like a corner carver put a 6point roll bar in it.
Old Oct 20, 2004 | 01:06 PM
drop-top IROC's Avatar
Engine: 305 TPI (LB9)
Transmission: WC T-5
Any mod. that will stiffen the frame (Subframes, STB, etc.) will definitely help. I have the Alston/TDS subframes and it made a world of difference, but I'm still thinking of adding the Spohn SFC's in conjunction with what I already have, since it's still not as stiff as I want it. IMO, convertibles handle like a wet noodle in stock form. ASC did add what is essentially an SFC (although it doesn't really connect to the subframe) to the outer rail of these cars, but from a performance standpoint it falls way short...
You may also need to tighten the top frame itself (joints, etc.) I just had a new rear window installed in my 'vert a couple weeks ago and just by R&R'ing the top, now that it is on a little tighter, it took a lot of the creaks and squeaks out of it.
Old Oct 20, 2004 | 01:38 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
because my convertible wasnt abused by its previous owners (i admit, im hard on her) my vert actually felt TIGHTER then the other 3rdgen coupes ive owned.
yes they still flex... if you put one knee on the center console, and the other knee on the door and go up a incline at a angle, you can feel it flex.
but with SFCs, they tighten up well. it certinly doesnt do it bad enough to take away the enjoyment from the car.
matter of fact, with the top down, because theres nothing to contain and "amplify" the interior noise, its rattle free. the only annoying noise in my car is one of the bows in the top... and thats a car prob specific to my car, not a usual one.
as far as underpowered... well, in my opinion, all 3rdgens are underpowered, however, the verts are no worse off then any other 3rdgen, other then the fact that you cant get a 350.
buy one and enjoy.
Old Oct 20, 2004 | 02:37 PM
89rsragtop's Avatar
Car: blue
Transmission: 6 speed
Axle/Gears: 3.73 posi
IMO if you go for a vert you must also go for SFCs and STB and make sure the STB is a three point unit. This will cut down cowl shake. The only noise mine makes is when the top is up (it rattles)
Old Oct 21, 2004 | 03:08 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Thanks guys, really want one!! May have to Import from the States.... Some good ones on ebay over there.
Old Oct 21, 2004 | 03:29 AM
custom88camaro's Avatar
Car: 88 camaro
Engine: carby 350
Transmission: t-5 from v6 car
'vert handles awesome
One of the stiffest, best handling cars I have driven was a 'vert. Why??? 6 point cage!!! Not only good for handling, can be effective at preventing headaches in unlikely rollover.LOL. Looks awesome. Did I mention looks awesome?? Car also had SFC's, STB, Poly bushings, and 17" Toyo T-1S. Almost forgot, had drop springs too.
Old Oct 21, 2004 | 06:43 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
6point here...
http://www.cecoatings.com/images/Car...shieldshot.jpg
Old Oct 22, 2004 | 07:49 PM
Speedgraphic's Avatar
Car: '90 RS Vert
Engine: 305 TBI
Transmission: 700-R4
STIFF
I have the Alston SFC's and a Three Point Edelbrok STB on my car. I upgraded rubber to larger 16x8 4th gen rims and Goodyear Eagles 255/60. My car will carve a corner with just about anybody.
I have a friend who has a hardtop GTA. He claims my vert is stiffer than his car...
One other thing that will help a lot is to replace the door bushings. On a unibody car the rigidity of the door has a lot to do with the rigidity of the car...
Good luck getting your 3rd Gen Vert in the UK. Send us some pics when you get it on the road!
Speedy
Old Oct 23, 2004 | 03:55 AM
Charlie's87's Avatar
Car: '87 t-top, '88 'vert
That, plus the fact that you couldn't get any decent gears on the 'verts, other than G92 being offered in '87-'88 only. My red car has the 3.23 rear, and the black one the 2.73, and the difference is like night and day. But guess which one turns more heads?
Old Oct 24, 2004 | 05:54 PM
AutoRoc's Avatar
Engine: Vortec 4200 Inline 6 PT70 Turbo..
Transmission: 4L65E
They are very slow and flexible. I did an 8 point chromo rollbar welded to a set of Southside Machine subframe connectors undrneath. Not sure if I want a STB yet but the Edelbrock TBI unit looks the best IMHO. I went carb also so the TBI setup fits me, not the TPI unit.
The subframe connectors alone really do stiffen the car and let the suspension do what it's supposed to do.
Safesty wise also...I totalled my first IROC-Z(first car owned also) 3 days after having SSM Subframes welded in. If you look at the pics of the wreck, 45mph into the side of a Dodge Dakota, the entire engine bay crumpled and the damage stopped where the subframes start. Luckily that happens to be where the passengers feet were in my case. I parted that car out, cut the subframes out of it and they were perfectly straight and now they're on my convertable.:hail:
Old Nov 20, 2004 | 09:07 AM
JWKbride's Avatar
Car: 1992 Pontiac Trans Am Convertible
Engine: 305 H.O.
I'll tell everyone my car is "No Speed All Class"
A friend of mine once told me your car can't be all things....so I don't care about fast. The 305 is respectable, has nice exhaust tone and is a good cruiser....race car it is not.
Im happy to own a rare 3rd Gen Vert. Long after others have encountered big buck repairs or investment trying to have the fastest car on the street (and there is always someone faster, just ask John Force) I'll still be getting the thumbs up from fellow drivers and compliments on my vert.
Old Nov 20, 2004 | 08:57 PM
92droptop's Avatar
Car: 1992 Camaro RS Convertible
Engine: 3.1
TPI383
How much do you feel that the roll cage cuts down on your visibility and feeling of openness??? One of the things i love about these cars is how big and open they feel when the top is down. I've been contemplating putting in a cage when i redo my car (aka when i get a full time job and have some money). I'd hate to lose that if it can be avoided.
Old Nov 21, 2004 | 12:57 AM
Bill Speed's Avatar
Car: 1989 Formy droptop/88 Deville
Engine: L98 350 TPI
Transmission: factory RWD, WS6 susp
buy one and enjoy.
But, fact is...You can get a 350, and even mod it up from the stock 235hp! Even aftermarket modded, add a stickshift manual.
I want to keep passenger option open, therefore, nothing visable like a roll cage. My car has served as dailydriver and typically at regular speeds so a roll cage and 5 point harness aren't really needed. If you've seen Ed Hamburger's SLP 3rd gen verts, you know with the right cage and harness...with all the SLP goodies, they look ready to take on all comers!!
Bill
Old Nov 21, 2004 | 07:59 AM
JWKbride's Avatar
Engine: 305 H.O.
A trend Im starting to see more of is replacing the TPI 305 or 350 with a LS1. Hawks 3rd Gens had the cover car in High Performace Pontiac w/ an LS1 and a roots type Supercharger seting on top.
Being just a two hour drive from his South Carolina shop I know of a couple of his cars....one being done now.
Out the door with Mod'd LS1 and 6 speed is in the $7-8K range. 400RWHP and 28MPG is a good thing.
Someday, I would like to do the same but my current 305 (Remanufactrured by Jasper) only has 15K miles on it so I will wait at least a few more years...Hey by then I can get an LS2
Old Nov 21, 2004 | 08:22 PM
LBSZ28BLOWN's Avatar
Car: Devastating Droptop
Engine: 355 Supercharged
Transmission: Auto 4L60, Built for 700hp
Mine seems tight , and I think there's plenty of POWER.
Old Nov 21, 2004 | 08:36 PM
JWKbride's Avatar
Engine: 305 H.O.
LBSZ28...wow very nice. What kind of dyno numbers are up pulling with that SC'd 355??
Looks great. Here a pic of the engine bay of my other TA...Mod'd LT4 366RWHP
Old Nov 21, 2004 | 11:01 PM
Bill Speed's Avatar
Engine: L98 350 TPI
You might have seen the Paxton Camaro TPI supercharger kit on eBay a few weeks back ...around $650 or so, but ended near $1300 final win price
Still reasonable? Sounds like alot of cost in engine mods too! How much HP did that get it up to and is that a 350 overbored? I'm not aware of all engine sizes, novice that I am haha
I see the brace between strut positions, but not really mounted to them, requires welding joints?
Bill
Old Nov 22, 2004 | 06:37 AM
Back in the spring on a DYNOJET it put out 418rwhp and 443 rwtq
at a AFR of 12.4 spaying Methanol, thats right at 500hp at the crank, I'm in the process of doubling the boost with a VR4 Supercharger upgrade should have new Dyno and drag strip #'s
next spring.
Old Nov 22, 2004 | 06:44 AM
Bill
Yes, lots of money in the engine, trans, and car.
The engine is a 350 4 bolt bored .0.30 over built by KIM BARR Racing, it has all forged internals, O-ringed cylinders, copper
head gaskets, and much much more, and there are a number
of chassis and suspension stiffening mods.
Old Nov 24, 2004 | 04:57 AM
Bill Speed's Avatar
Engine: L98 350 TPI
Do copper gaskets benefit a stock L98? How about manifold gaskets? I likely need a new set, and possibly new heads or re-machining mine. I got a Felpro set off eBay but they were damaged and, I, being a novice, didn't realize they wouldn't work unless completely flat and unmarred.
Bill
Old Nov 24, 2004 | 06:42 AM
Bill
Copper head gaskets are only needed in a high boosted engine.
I had them installed and the block milled for Stainless Steal O-rings, so I wouldn't need to be changing or blowing head gaskets.
I'm runing the Blow proof copper header gaskets also.
I don't like doing things more than once so I built this car/engine/trans with overkill in mind.
Old Nov 24, 2004 | 06:58 AM
Bill Speed's Avatar
Engine: L98 350 TPI
I like that ideology. People I work with say there are many sub-standard gaskets for these cars, and recommend nothing but Felpro to go with. I've read this on eBay as well... Was looking at Mr. Gasket, but they say 'no'
I'd like to change to stainless steel pipes and headers at the very least... to up performance and kill replacement there
Bill
Old Nov 24, 2004 | 10:15 PM
Nate86's Avatar
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
Louis, I just wanted to say :hail: :hail: to you... Great car man.
Old Nov 27, 2004 | 03:19 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
You are just a freak though. Best 3rd Gen Vert I've ever seen.
Sorry for gushing.
Old Nov 28, 2004 | 09:31 AM
cdartz's Avatar
Not to sound like a sceptic, but that's a bit hard to believe considering you don't list aftermarket heads in your mod list, not to mention that cam is enormous for stock heads.
Old Nov 29, 2004 | 03:59 AM
Bill Speed's Avatar
Engine: L98 350 TPI
The Firehawk drop tops get my vote for best ones ever, but it's certainly a super 3rd gen!
Bill
Old Dec 4, 2004 | 11:21 PM
There not stock heads, they are the alluminum L98 heads ported & pollished by GTP out of Houston 2.00 int. & 1.6 ex undercut Valves and have been milled to handle .600 lift with out coil bind, The Cam is also a custom one of kind Blower grind made for this engine by CompCams.
I guess I need to work on updating my mod list and web site,
maybe I'll do that during the hollidays.
Here's a pic that shows the heads on the engine while on the stand.
Old Dec 5, 2004 | 10:48 AM
Bill Speed's Avatar
Engine: L98 350 TPI
While I paid $8600 for my car... I heard someone here quote a crate motor that may have had mods at $7000 ready to go, How much was the work on that motor you had done, if you don't mind the Q? What did you save from the stock setup, how many miles were on that and was it in need of hi-perf makeover?
Bill
Old Dec 5, 2004 | 11:42 AM
cdartz's Avatar
Ok that makes more sense.
Old Dec 5, 2004 | 12:09 PM
Bill
I think I have over $10,000 in it, but that includes everything New
callies forged crank, egle forged 6 in rods, custom JE forged pistons, All new ARP hardware/Bolts and nuts, New TPIS big mouth Lower Intake Ported big time to match my big ported heads and Large tube runners, new 6qt oil pan with scraper and windage tray, new high flow oil pump with Heavy duty drive shaft,
and much more.
Old Dec 11, 2004 | 06:24 AM
Bill Speed's Avatar
Engine: L98 350 TPI
Just looking at the paper today at cars listed in the Thrifties section; Northstar eq. mid-1990s Cads listing at less then $5Gs, it's true enthusiests that go that extra mile. I don't know if I have that fervor, but I know I did appreciate switching to new wheels everynow and then and that makes it hard to decide to live with the car you have. I just got my legal problems taken care of the past week, all springing from my Firebird breaking down and looking for a 'winterbeater' last year. Now I have two cars not working but the Bird is being readied for action again...slowly
Attached Thumbnails Camaro 'Verts are weak, creak a lot and underpowered?-payday-1.jpg
Old Dec 17, 2004 | 12:49 PM
Cadillac's Avatar
LOOK! It's Ted Nugent!
Cadillac's Avatar
(scrambling to cover double post)
Old Dec 17, 2004 | 03:42 PM
Bill Speed's Avatar
Engine: L98 350 TPI
Back when I had money...sorry it's so big. Speaking of Ted, I'm looking for his New Years Eve 1988 Whiplash Bash... That concert rocks!
My buddy has a related question about the engine pic, it looks like the cast iron block used in the pics, he's wondering why the expense and then building on that?
Bill
Frozer!!!
Jan 19, 2024 04:55 PM
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
Wesly_66
Aug 26, 2015 09:55 PM
Akinnepa
Convertibles
Aug 26, 2015 10:54 AM
justin57
Aug 20, 2015 07:05 PM
