fender pictures
Old Nov 18, 2005 | 01:17 PM
Daves Iroc's Avatar
Car: 89 Iroc convertible,80 Z/28 350-4sp
Engine: 305 TPI but now has a 350
fender pictures
Modification needed.
Old Nov 18, 2005 | 01:18 PM
Daves Iroc's Avatar
more pics
modification needed
Old Nov 18, 2005 | 01:24 PM
Daves Iroc's Avatar
more pics
modification needed.
Old Nov 18, 2005 | 01:29 PM
Daves Iroc's Avatar
fender pics
Last one finally !!!, you can see that a regular Z fender has to be trimmed in order to fit the box frame that has been added to the convertible. I did trim off about 5 inches so that it will set down where it needs to be. Thanks for being patient.
Old Nov 18, 2005 | 11:00 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
I will measure and take pic's for you 2morrow if you still need them.
I have a regular and vert fenders up at my shop I can layout for you.
Old Nov 20, 2005 | 02:37 AM
911rsq's Avatar
Car: '91 Z28 & '90 RS Vert & '89 RS
Engine: 5.7L & none & 2.8L (soon to be LSX)
Transmission: yes
Axle/Gears: One's with teeeeefs
So this special bracket....where does it mount up? Does it just bolt the bottom of the fender to the vert bracing ? TPI383, if you could post them up that would rule !!!!!!!!!!!!!!!
Old Nov 28, 2005 | 04:11 AM
911rsq's Avatar
Transmission: yes
I would still like to see some of that bracket that everyone is riveting on there, and a pic of it installed.....
Old Dec 16, 2005 | 11:08 PM
sunbitz's Avatar
Car: 91 RS Convertible
Engine: 305 TBI
I just had to replace the drivers fender on my vert and the body shop took the "modified" bracket off my old fender and welded it onto the the fender off a coupe.
It lined up perfectly. They did have to do some cutting, but you can make a coupe fender work on a vert.
ASC did a chop shop job on the verts and any body shop can do the same.
I pulled the panels off the rear one time to install new speakers.... and the left side of the car has different bracing that that of the right hand side of the car, and a nasty weld job ta boot.
morrow
Jan 13, 2024 12:29 PM
Bohemian
Aug 15, 2017 05:11 PM
tonys91rs
Oct 10, 2015 03:31 PM
Linson
Sep 21, 2015 01:08 PM
Strick1
Sep 6, 2015 02:21 PM
