Seatbelts!
Car: 1987 Chevrolet Camaro Z28 IROCZ
Engine: L98 350, mini ramed and camed
Transmission: T56 6 speed manual
Axle/Gears: 10 bolt 3:73 limited slip
Seatbelts!
What to do for seatbelts. I can't find a good factory set anywhere. And I saw a picture of forth gen vert seatbelts. And theres no way those will fit. I think I am just going to go with these. 3" lap belts. I think that will work. What other options is there? Adam :-)
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Interesting. I need belts too and am frustrated wit hthe options especially in my color. Where are you seeing those? Are they listed as a replacement for ours? What kind of costs are you looking at?
Car: '89 t-bird SC/87 Z-28 vert
Transmission: auto
seatbelts
Try "unclefrank@aol.com" this guy has well over 50 camaros he's parting out.
Seems like a real honest guy also. Just ordered some parts from him. If you work with him be patient sometimes it may take him a few days. Rick
It's not a replacement type belt. It's a 3" lapbelt for race cars. But it will bolt into the car. But you will have no over the shoulder belt. Adam :-)
Car: 1992 Pontiac Trans Am Convertible
Engine: 305 H.O.
Buddy of mine turned me on to this solution.....a seat belt rebuild kit.
It costs about $17 and you can order at www.moderndaymuscle.com This is a great fix for those sun faded buttons, especially in a convertible. Makes your seat belts look new...and it's inexpensive
Before
After
Before
After
Car: 1991 RS Convertible
Engine: 305 TBI
Re: Seatbelts!
What belts are compatible with a 1991 Convertible? I am restoring my vert to all black, new carpet, leather seats, et al. My problem is with seat belts. I have 4th gen seat belts from a 2000 Camaro SS Convertible and I have them from a 2002 Trans-Am hard top.
I saw the tech article about 4th gen to third gen belts but nobody ever answers the convertible question...are our seat belts different? I would assume so. Anyone put 4th gen vert seat belts or others in their 3rd gen vert? Also, the tech article mentions a gaping hole that doesn't get covered...I am assuming this is the hole in the door sill. Anyone figure out how to cover that?
Also, will 3rd gen hard top belts work in our 3rd gen verts? I know there are a lot of seatbelt posts but none answer or give a "compatability matrix" of options.
Thanks for you help!
Visit my garage: https://www.thirdgen.org/forums/vbga...ber-63078.html
See a burn-out post flowmaster install and pre-new tire install on YouTube: http://www.youtube.com/watch?v=d3MiOJFGyS8
Engine: 305 H.O.
Re: Seatbelts!
Here is a set on Ebay. Also try Hawks 3rd Gens...he has a lot of converts on his lot that he is parting out.
http://cgi.ebay.com/ebaymotors/1992-...09779906QQrdZ1
Re: Seatbelts!
Engine: 305 TBI
Re: Seatbelts!
Hawks didn't have any and neither did Zues Performance. It is like a frigg'in wasteland for good looking black belts that fit in a 3rd gen vert.
I have two sets of 4th gen's in black but they don't fit right. I bought 4th gen camaro and t/a seats and each set came with belts.
https://www.thirdgen.org/forums/inte...-two-sets.html
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: Seatbelts!
You can still get the buttons through the DEALER, they were only $2.00 last year for the set of 4. ModernDaymuscle in this case is overpriced... Although if you don't want to go through the hassle, they might be a good option as I have done business with them and been happy.
You need to read through the recall on the buttons for our cars to get the proper kit number...
The only problem I have is getting the originals apart to replace the inards... maybe thats why ModernDayMuscle is more they might come with the tools.
John
John
Car: 1991 Deep Red Z28 Convertible
Engine: 5.0 TPI
Re: Seatbelts!
I have also had a hard time finding a replacement set for my 91 vert. I need a set of flame red front females. Anyone?
Re: Seatbelts!
I just purchased some NEW ones from GM last summer, I was able to get them in GRAY. but the ones I got were for 1992's, they appear the same as the 1991 & earlier but they apparently have been revised as there was not a recall on them...
John
John
Engine: 305 TBI
Re: Seatbelts!
I am still looking for 1991 camaro black rear seatbelts with the shoulder pull-down that comes out of the convertible tonneau cover. Thanks again for the tip!!
Re: Seatbelts!
The RECIEVER part is the same as the Hard top cars, the belt is different, I accidently ordered a belt for a hard top instead of the reciever...
John
John
Re: Seatbelts!
Thanks for the tip! I just ordered new front black belts for 1992 camaro convertible from my local dealer. $114.47 for each front retractor (~$230 for both) and will be here by Friday! I don't need the receivers but they had them for ~$70 each...ouch! They didn't have any belts for 1991 but they had the 1992 ones. The 1992 rears won't work because they changed them that year.
Re: Seatbelts!
From 1989-1991 the rear seat belts had a seperate shoulder harness clip that went into the reciever. I believe in 1992 they changed it so the belt was 1 piece... I think its similar to the 4th gens... not sure though... Its been 10 years since I owned my 95 Formula vert.
John
John
Car: Black '89 IROC Convertible
Transmission: 700-R4
Re: Seatbelts!
Relieved to see this post up. I am doing the same thing to the interior of my 89 vert. Going from all tan interior to black, and finding seat belts in respectable condition has been more than easy. Just have a few ?s. The new belts that were bought from the dealer are front belts correct? Do the convertible front belts differ from t-top belts? I had read a post a while back that said they were the same belts just flipped over? In any case, glad to hear that GM still stocks them in black. Was about 2 days from pulling a pair at the local yard from a t-top car. Getting them new will be great.
Re: Seatbelts!
The only seatbelts that fit a thirdgen convertible are thirdgen convertible seatbelts. Adam :-)
Engine: 5.0 TPI
Re: Seatbelts!
So can you order the front receiver belts from the dealer and will they fit a 91 vert? All I need are the front receivers.
Re: Seatbelts!
Yes they should fit. The recievers from 84 - 92 were basically the same, From 84 - 91 there was a recall but the issue was apparently corrected for 1992. The 84-91 belts plug into the 92 recievers...
John
John
Re: Seatbelts!
Is there a specific part number for the black front vert belts? I have called a dealer around me and they have told me that the belts are discontinued. Perhaps I had asked for 89 belts and not 92 belts. I am very interested in getting 2 black front retractors for driver and passenger. Could you guys who have recently gotten the belts new let me know what I have to do to track these down.
-Matt
-Matt
Car: 1987 Iroc-z Convertible
Re: Seatbelts!
I know a place that can restore them to new condition but it cost about the same as getting new ones. But the good thing is the webbing is replaced and the plastic is also redyed. This is good for the guys like me that don't want to change out the whole interior to a different color. I think for the entire set (2 front 2 rear) I am fairly certain it was $350-400 range I could be off but that should be close.
Car: 1987 Iroc Convertible
Engine: Bone Stock, 66,000
Transmission: 5 speed
Re: Seatbelts!
I have an 87 convertible with carmine red interior. I just picked up a set of set of front and back buckles. I need new retractors for the fronts because they do not retract. My belts are also a little discolored and I would like to replace them. Anyone know where I can get a new set of carmine red belts and retractors
Re: Seatbelts!
Vert seatbelts are the probly one of the hardest peices to find for the car other than the plastic peace right above the winshield...i have been looking for a black set in good condition sence i got my car.
kinda looking for someone that would trade my red set for their black set
Car: 89 Iroc Convertible
Re: Seatbelts!
I got some grey seatbelts out of an 89 Iroc vert that I found in a local junkyard.It had the front and rears intact.I wasnt able to get the the ones mounted on the underside of the tonneau cover as it was gone before I found the car
Check this out.They are Black vert belts and are suppose to be in great shape but I belive she wants a fair amount for them..http://philadelphia.craigslist.org/pts/628411618.html
Re: Seatbelts!
Cool z, if you find a set of blacks what are you gonna do with your reds? Will they fit my 87 convertible?
From: Avatar: My 34' 1989 Scarab III w/ twin 454's (502's Started!)
Car: 1989 Wellcraft Scarab III
Engine: Twin 454's
Axle/Gears: Twin Mercruiser Bravo I's
Re: Seatbelts!
Could you post the name of this place you are speaking of or PM me the name? I'm hoping to finally begin the restoration of my IROC this upcoming fall and need to get my sources in a row.
Thanks in advance.
Re: Seatbelts!
if i found someone with a pair of black id trade them for my red but if i found a set of black id probly sell on this site...and i do beleave it would fit im not totaly positive thow is the 87 the year that ACS did the converson by themselfs or was that when they went with the company?
xbazzarex
Dec 1, 2015 05:25 PM
KNIGHTE
Southern California Area
Oct 22, 2015 09:11 PM
