91 Camaro Convt springs
What is the best way to lower my suspension about 1". I see Tenzo springs but I also see that most of them say not for Convertible. What is the Diff? Or am I reading this wrong? Any help would be appreciated.
Car: 1991 Z28 Convertible
Transmission: 5 Speed
Re: 91 Camaro Convt springs
I found they all say not for convertibles, and I went through this in here a year or so ago. Seems it is a weight difference and the drop will be different than what the manufacturer advertises. My memory says there are no appreciable differences in the mounting or installation. Again, I believe the weight is displaced differently on the verts and that is why the "not for convertibles" statement.
I'll see if I can find the old thread.
Car: They all sit.
Engine: LS1, LB9, LB9, L98, LT1, LT4, LT4
Transmission: A4, T5, T5, A4, A4, T56, TR6060
the rear inner fenders on the convertibles are not rounded on the tops like the coupes, they are cut off and flattened for the top to fit. reducing the clearence between the tire and the top of the fender well. i had a big drop on my 91 vert and it bottomed out all the time. no big deal for me but thats the difference. you can use any spring but the lower you go, the closer you'll get to rubbing.
Car: 91 Firebird
Engine: 6.0
I've had no issues using Eibachs Pro-kit on my 88 vert or my sisters 91 vert
Thats only a 1" drop or so, plus it helps to use a quality shock/strut combo
-jason
-jason
Car: They all sit.
any spring will work as long as you dont try to lower it to the ground. good shocks and struts will also help greatly. i had a 2" drop in mine and i rubbed with my 16's and 20's between 1-1.5 should be fine.
Car: 91 z28, 07 trailblazer ss
Engine: lt1lt4 hot cam,ls2
Transmission: t56
stay far away from tenzo. my 1.6 drop was more like a lift kit. There getting cut when the z is back on the road
Car: 91 z28 convert
Transmission: 5speed
try that first.
Car: '89 Black IROC 'vert
Transmission: 700-R4
Axle/Gears: 2.73 posi
Car: 87 GTA
Easiest way is to cut 1/2" or less off your stock springs.
People might give you the "hack" job routine, but I've done it on two 3rd gens before, and took both of them to autocross afterwards, will no ill effects.
Car: 87 GTA
You are going on assumption, obviously, not experience.
I've done it twice, on my own cars, and will continue to do it in the future, on my own cars.
If it rode that bad, would it even remotely be an autocross car?
Car: 87 iroc droptop
Engine: 350 tpi
Transmission: 700 r4
Axle/Gears: 373
i put eibach springs in my convert 5 years ago, and haven't problems
I put on lowering springs, they were about three inches lower than stock springs, but much thicker. My car now actually sits about an inch higher than stock. Really weird. I am going to cut my stock ones and put them back on. Maybe the verts are just lighter, not sure.
Car: 87 GTA
Take your lowering springs off, cut a coil off all 4 springs, coil & a quarter, MAYBE a coil & a half (up front), then put them back on.
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
I'm sitting @ 28 in the front, 28.5 in the rear with moog 5662/5665 springs. Heater hose isolators in the rear.
Car: 1991 Trans Am convertible
Just installed Eibach front and rear. No problems and it lowered a good inch. Also installed KYB shocks and struts. Very good.
sailtexas186548
Aug 26, 2015 03:32 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
