need pictures of the tonneau rods..
Old Mar 7, 2008 | 01:20 PM
11sORbust's Avatar
...the rods that support the cover when open. I'm trying to bring an 88 vert back to life. The previous owner disassembled the car for paint and did nothing afterwards. Half the parts were lost. I have everything to get the tonneau cover to bolt up. Problem is when everything is bolted up, there is no tension. The rods are loose...
Old Mar 7, 2008 | 03:10 PM
gatorcola's Avatar
Car: 88 IROC Z Vert CZA3
Engine: LB9 5.0 tpi
Transmission: MM5 5 spd
Axle/Gears: G92 Performance
Re: need pictures of the tonneau rods..
Here you go - from a 1988 IROC - just took them and from the looks of it, I'm going to have to was and wax the underside.
Attached Thumbnails need pictures of the tonneau rods..-dcp_3624.jpg   need pictures of the tonneau rods..-dcp_3625.jpg   need pictures of the tonneau rods..-dcp_3626.jpg
Old Mar 7, 2008 | 07:07 PM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Do you mean the 2 tonneau cover support arms?
Or the tension arms underneath that act like springs?
That's the best pic of mine that I have right now.
Old Mar 8, 2008 | 03:17 PM
Crouchman's Avatar
Car: 1988 Iroc convertible
Engine: 305TPI
Transmission: T-5, swapped it in.
Axle/Gears: no clue, but I'll learn
I have the same tension rods as topless, rod release like gator. Had a heck of a time finding a replacement release for the rod system for my 88. Finally got one after about 6 months of looking. Anyone know where you can find the plastic connectors that the rods are connected with? Mine seem ok now, but a couple spares wouldn't hurt.
topless, dumb question...who's the dude in your photo? I assume that's you in the vert. You don't look like the guy in your ID stuff. :-)
Old Mar 9, 2008 | 09:51 AM
11sORbust's Avatar
Thanks gatorcola, not the pics I was taslking about but I will save those too. I need more shots like Iroctopless posted...
Old Mar 9, 2008 | 12:46 PM
Axle/Gears: 3.08
My car is covered and in winter storage in my garage. With the weather getting more Spring like (above freezing), I'll try to get into the back of the car and take a few more pics. Might be in a day or two.
Old Mar 9, 2008 | 01:02 PM
Axle/Gears: 3.08
For now, I've created some snapshots of this area from the ASC assembly manual. Hope this helps a little . . .
You can download this entire manual elsewhere on Thirdgen.
Old Mar 10, 2008 | 10:26 AM
11sORbust's Avatar
That is exactly what I need. Do you have a link to the manual? I cannot find it though searching...
Old Mar 10, 2008 | 09:39 PM
Axle/Gears: 3.08
There is a Sticky here but I'm not sure it works.
I also got a copy of it here . . . http://www.4shared.com/file/10485107...9a/ASCTop.html
Old Mar 14, 2008 | 09:47 AM
Axle/Gears: 3.08
Here are some pics I just took. My car is still in winter storage so the pics aren't the greatest. I had to shoot them in the dark (trying to guess where the camera was pointed) from the back seat. The car is backed against a wall and the battery is still out, so trunk side shots were impossible.
Hope this helps . . .
Fronzizzle
Feb 9, 2017 09:31 AM
Linson
Sep 21, 2015 01:08 PM
okfoz
Sep 17, 2015 10:30 AM
Street Lethal
Sep 7, 2015 01:09 PM
Strick1
Sep 6, 2015 02:21 PM
