Replace Carpet: ACC or ????
Old Jun 13, 2008 | 10:01 PM
damage31's Avatar
I guess I have a huge water leak coming from somewhere this year that I didnt have last year...my carpet and padding is completey soaked on thed drivers side coming from the rear and is now completely toast. (but my seats are all dry...and under the toneau is dry, and trunk is dry...I guess its time to start replacing some of the rubber seals on this thing to try to fix the issue. It appears to have water in the bottom on the drivers side in the quarter panel if i look down where the top is held to the car frame wher the shoulder seatbelt.
Anyway, I'm thinking of using ACC carpet, but I dont know what to buy, as I cant find a listing for convertible carpet. Is there such a thing? Anyone replace their carpet with ACC, or any other brand and have some ideas/pointers about what to buy? Or is the convert carpet the same as the regular camaros?
Old Jun 14, 2008 | 08:24 AM
tavert91's Avatar
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
Re: Replace Carpet: ACC or ????
Carpet should be the same for both the coupe and the convertible. It was for my TA. If the water is behind the driver's seat, you may want to see if your window seal along the rear edge of the driver's window is making a good seal.
I am not familiar with ACC carpet, but any good brand that won't fade will probably be fine.
Old Jun 14, 2008 | 10:54 AM
damage31's Avatar
As far as carpet goes, price is not an object.
If I can find new GM OEM dove gray I'll buy it....but other than that I see ACC all over the place, but I have no expierience in this area to know if they are in fact good, or if there is better out there.
I'm most interested in a good fit and finish to the carpet.
Old Jun 14, 2008 | 06:00 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
I bought my replacement Dove Grey carpet from Year One, which I believe uses ACC carpet. It is junk. I had to have them send me another replacement after 6 months because it had faded to a greenish blue from the sun.
Old Jun 16, 2008 | 12:03 PM
Scooby Doo's Avatar
Car: 92 Trans Am Convertible
Engine: 5.0L
Hey Nick, I replaced the carpet in mine from stockinteriors.com, some people on the local board recommened them, so far I am pleased, although I have seen much of my car lately.
I remember thinking when I was putting it in that if this was a coupe this would be a much worse job.
Good luck fixing that leak.
http://www.stockinteriors.com/items...._Camaro_Carpet
Old Jun 16, 2008 | 02:31 PM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
The carpet thing is a mess...
ACC makes the fading carpet... ACS made the better quality carpet, ACC bought out ACS! You can still get some of the ACS inventory, what I did, I picked up some acs inventory beechwood carpet / mats and extra carpet too... There is limited remaining supply...
Ask stock interiors if they use ACC... ACS had an Essex, higher count premium carpet available in limited colors, but it is nicer, and with the rubber backing too...
Raf
Old Jun 17, 2008 | 09:17 PM
88Convertible's Avatar
Look up Jim85Iroc he is a moderator here, He owns Iracemotorsports, Do a search it will come up, I bought new carpet from him awhile ago, I want to say over a year ago, And it still looks like the day I put it in.
You might pay alittle more than on ebay or something but definatly worht it.
Old Jun 19, 2008 | 07:55 PM
kramer87gta's Avatar
Car: 1987 GTA Vert
Axle/Gears: ?
Yeah i bought the ACC dove grey as well and it faded, i had to cut it a little as it didnt fit exactly, im thinking of getting anonther peice or having them replace it, granted i dont know what the return policy is for it has i bought it a couple of years ago and the car has been on the road maybe 10 times since.. but overall not a fan of acc
Old Oct 12, 2008 | 07:42 PM
FUNIROC's Avatar
Car: 1989 IROC
I am thinking of going with the carpet and mats for this site: www.autocarpetonline.com
They have a lot more options than the others, but you are going to pay for it.
Old Nov 25, 2008 | 06:58 PM
88GTAvert's Avatar
FUNIROC did you purchase carpet from this place? If so, how do you like it? I'm looking to get some new carpet and I only want to buy it once
Old Dec 6, 2008 | 07:20 AM
sassieroses's Avatar
i too will be replacing carpet and only want to do it once any help?
ebay, hawks ,???
Old Jan 17, 2009 | 08:07 AM
88GTAvert's Avatar
Last month I ordered carpet for my car from Ebay. When it arrived it had ACC markings stamped all over the box. I installed it anyway, despite what I've read in this thread, and it worked out pretty good.
I had to trim some areas along the sides facing the doors and cut holes for the seat studs, but overall it worked out nice. The area under the rear seats and over the rear floor "hump" doesnt fit as nice as I would have liked though. Seems to be extra material over the hump which looks a little sloppy.
Just happy to have replaced the trash that was in there!
TheJoeY88
Dec 31, 2016 07:30 PM
lee01
Apr 9, 2016 01:56 PM
stalkier
Aug 21, 2015 01:54 AM
Dan Hubbard
Aug 12, 2015 09:05 PM
Fronzizzle
Aug 9, 2015 01:15 PM
