a couple questions...
Old Feb 10, 2010 | 07:36 PM
musclecar70sfan's Avatar
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
Hey guys, I was always wondering what this thing that I'm pointing to in the picture is called and where I can get a new one, since I think I might peel it off before I bring the car in for painting. I'm assuming its there to protect the paint from getting scuffed from the top?
And how do I get the rear spoiler off? I removed the nuts on the part mounted to the trunk lid but there's still something holding it on and I'm afraid to break it.
And I'm clueless as to how to remove the two parts mounted to the quarter panels, any help?
I did notice this rivet here though, do I drill it through?
Thanks guys!
Old Feb 11, 2010 | 01:40 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: a couple questions...
Yes you'll have to drill out those rivets. On my 90 those are screws not rivets. They attatch to a bracket that slips under a hat-shaped sheet metall piece that is riveted to the trunk lid. You can use screws or pop-rivets to re-install the brackets afterward.
Lon
Old Feb 11, 2010 | 06:10 PM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
That's a film applied to the paint to protect it. This is due to the roof and rear seal sitting dorectly on a painted surface. I don't believe anyone makes a precut plastic film for that area, but that's not a big deal. 3M sells tons of that material and it can be cut to fit, or you can go to any of the many auto detail shops that install custom "invisible bra applications".
Old Feb 11, 2010 | 06:24 PM
mister_hudson's Avatar
Car: '92 Z28 Convertible
Engine: 305ci TPI
Transmission: 700R4 shifted
Axle/Gears: 2.73 (for now)
I've been wondering the same thing! I just want to make sure that it is just as durable and one piece...
Old Feb 11, 2010 | 09:26 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Do a search here on that plastic film part. I remember a certain member here was gonna custom make and reproduce those and had them for sale a while back.
Anybody else remember who it was???????????
Old Feb 13, 2010 | 05:02 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
That 3M rock chip guard/ paint protection isnt cheap.
I need 2-3 sets of it 4 the verts around here.
Id like 2 have it die cut 2 exact size instead of just using a knife or sissors.
I should make a pattern 4 all 3 pieces and take em 2 my buds decal shop 2 c if he could do it..
Old Feb 13, 2010 | 05:06 PM
Engine: 305ci TPI
I need one as well - as long as it's that thick & durable and doesn't cost an arm & a leg I'd buy one...
Old Feb 13, 2010 | 05:19 PM
Axle/Gears: 3.08
You want to avoid the cheap stuff. It can yellow or get hazy over time. And even though 90% of adhesion issues lies in the surface prep, the cheap stuff can also start curling at the edges. If that's the route you wanna take, you don't want to cut to many corners.
(oohhh, bad pun )
PS; some good links to previous posts . . .
https://www.thirdgen.org/forums/conv...eau-decal.html
https://www.thirdgen.org/forums/conv...protector.html
Old Feb 13, 2010 | 10:51 PM
Engine: LB9
Thanks for the tips guys! And back to the spoiler, so drilling out those rivets will remove it? And how do I remove the left and right sides of the spoiler that attach to the quarter panel? Thanks!
Old Feb 13, 2010 | 11:13 PM
lonsal's Avatar
Unless they are loose I don't recommend removing those side pieces. If you insist on doing it. they are attached with strong double sided foam tape. Use a putty knife, but be very carefull and go slowly. I've snapped a few off trying to remove them from 'verts at a pick-a-part yard.
Lon
Old Feb 13, 2010 | 11:26 PM
Engine: LB9
Lon
Oh ok. Kind of a hack-job way of mounting it but oh well. I thought I'd remove them before painting but if that's the case then forget it. Although I was thinking of getting a spoiler like this 87 convertible:
http://www.vicarimotorsports.com/198...0Prototype.jpg
Old Feb 14, 2010 | 12:27 AM
injdinjn's Avatar
Car: 1986 Grand Prix TPI
Transmission: 200 4R
A trick I have used to remove emblems is a heat gun and piano wire or fishing line. Might work on those fender caps.
Old Feb 14, 2010 | 12:54 AM
lonsal's Avatar
If that is your reason for removing them, I'm glad you're getting advice before doing it. Those side spoiler pieces won't work on your 'vert. Any Camaro side spoiler piece won't work because the Firebird body is wider than the Camaro. The center spoiler section is the same for Firebird or Camaro, but the side pieces are unique to each version of F-body.
Lon
Old Feb 14, 2010 | 09:34 AM
Engine: LB9
Lon
Did you look at the picture? The link was a picture of an 87 Trans Am convertible. Rare I know but I like its spoiler a little better. I wonder where i can get it.
Old Feb 14, 2010 | 01:49 PM
lonsal's Avatar
Sorry, no I didn't notice it was a firebird vert. Those side spoiler pieced will be tough to find. The center piece is modified from a coupe's spoiler. Maybe I can get Tom to demostrate the fishing line and heat gun method on one of the two 87 Firebird GTA 'verts in his family and send you the pieces.
Lon
Old Feb 14, 2010 | 05:01 PM
TTOP350's Avatar
I wouldnt use the cheap stuff 4 the scratch protectant decal either!
I just wouldnt want 2 buy the expensive stuff and then do a poopy looking hack job with a knife or scissors.
You can cut through the sticky tape on the spoiler parts w piano wire or a knife if you are very careful..
once its apart you can clean it off fairly easy..
Old Mar 7, 2010 | 08:23 AM
My86'stitsRout's Avatar
Car: 65 SS Impala,86vertZ28,88vertIrocZ
Engine: Stock 305 TPI
Transmission: 700R4 Automatic
Axle/Gears: Stock
www.vpartsinc.com has oem tonneau protectors for our cars from gm. I orderded two just to have an extra one on hand. (never know when they might run out ) Part# 12520107
Old Mar 7, 2010 | 12:54 PM
Axle/Gears: 3.08
For those who wanna try, templating a pattern first is the trick.
Then cut your piece on a bench using the correct tools. An exacto knife on a cutting surface using a template and patience for example.
Old Mar 7, 2010 | 02:19 PM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
or I can get a couple more made. I sold a few on here a while back. They were not perfect but not bad either. I had my cad guy do a template and then had them computer cut but they still needed trimmed a little. which isn't a huge deal since the tonneau covers weren't all stamped exactly the same. I am not trying to advertise just giving an option. I got the oem decals to use as a template so they are close. The vinyl I used is thinner than the original but stronger and better wear characteristics. also bad thing about the oem decals is that when you received them they are already yellowed from age. I sure didn't want to use that. your call though. still same price as when I sold the others $105 shipped through paypal. If I get a chance I may get all the way back into them and start selling to some thirdgen parts places in bulk then they can charge whatever.
Old Aug 13, 2010 | 11:11 PM
sergio's Avatar
Car: 91 T-am convertible
Engine: 5.0 TPI
Transmission: 5 speed manual
Hi J,
Have you had any takers? I am also looking for the protective film. Let me know if you are planning to run a batch.
Thanks,
Sergio
F-body-fan
Jan 12, 2023 01:49 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
RedLeader289
May 28, 2019 01:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Linson
Oct 1, 2015 09:50 PM
