Convertible Switch?
Old Mar 15, 2010 | 09:05 AM
biza1111's Avatar
Convertible Switch?
I have a 89 iroc-z vert. Where is the switch located to release the convertible from the trunk? can only release the top manually.
Old Mar 15, 2010 | 10:22 AM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Re: Convertible Switch?
There is no switch for the top. It's only operated manually. Two latches up front and a rear pin release lever along the side of the tonneau cover.
Now if you mean the switch to release the tonneau cover, it's generally located on the console between the power window switches . . .
Your '89 should have it here (newer verts can have it mounted on the tonneau cover). It's activates an electric solenoid switch to release the tonneau cover. If this fails, the back-up is a manual pull cable.
Old Mar 15, 2010 | 10:28 AM
biza1111's Avatar
Thats exactly what i need. Thanks for the pic.
Old Mar 15, 2010 | 11:11 AM
Axle/Gears: 3.08
Glad to help.
PS; Welcome to ThirdGen.
Old Mar 15, 2010 | 11:26 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
If you need that switch check out www.thirdgenranch.com
They should have one.
Old Mar 18, 2010 | 01:06 AM
Chezoom's Avatar
Car: 91 RS Vert, 87 SC T-Top
Engine: LO3, LG4
Transmission: 700r4's
Axle/Gears: 2.73, not sure yet
that switch on mine doesnt do anything. i pull it and it doesnt release the cover, how car i fix this?
Old Mar 18, 2010 | 10:42 AM
Perpendicular's Avatar
How are you opening the top cover? Is there a manual release and that switch has not worked since you got the car?
Old Mar 18, 2010 | 12:35 PM
flippermtc's Avatar
Car: 88 IROC T-Top
Engine: 5.7
Transmission: Automatic
Chezoom,
Could be any number of problems....Bad switch, blown fuse, short wire, bad solenoid. When you push your switch do you get any response? Is there a clicking sound?
Old Mar 19, 2010 | 12:07 PM
Chezoom's Avatar
Engine: LO3, LG4
Originally Posted by flippermtc
Chezoom,
it does nothing
Old Mar 22, 2010 | 03:05 PM
rext's Avatar
Where can the solenoid be bought? I think I have the same problem.I know the switch and actuators are good along with the fuse.Is it the one under the switch?
Old Mar 22, 2010 | 03:50 PM
flippermtc's Avatar
Car: 88 IROC T-Top
Engine: 5.7
Currently the solenoids are not being manufactured...Your best bet is to post a ad in the "parts wanted" section or look at e-bay...They come up from time to time..
Old Mar 22, 2010 | 06:59 PM
rext's Avatar
Where is the solenoid mounted?
Old Mar 23, 2010 | 01:07 AM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
Mount on floor Under the rear side panel. (The panel the rear speaker is in)
I have an extra pair of solenoids from a 92.
Old Mar 23, 2010 | 09:23 PM
Savo110's Avatar
Car: '91 rs
Engine: 305 tbi
Transmission: Manual 5
I have the same problem. The switch doesn't activate the 'noids. But when I do pull back the switch I hear a little click. Is it the fuse burned out or both 'noids not working? I can't tell.
Old Mar 23, 2010 | 10:03 PM
littlevin91's Avatar
Car: 1991 camaro z28 convertible
Engine: 5.0 v8
Axle/Gears: 9 bolt 3.23 borg worner
i have the same prob mine dosnt make any noise when i go to release it im thinking its the switch. but every1 should try a fuse test since sometimes u cant see the brake in the fuse thats happened to me alot
Old Mar 23, 2010 | 11:09 PM
Savo110's Avatar
Car: '91 rs
Engine: 305 tbi
Where exactly is the fuse for this switch?
Old Mar 24, 2010 | 06:08 AM
rext's Avatar
The fuse is in the fusebox labeled LID.There is also a relay or solenoid or something that I dont know where it is?I think that may be the culprit for most of us.You can test the "actuators" for lack of a known term, with a 12V power source to ensure they are working.I would think these dont go bad too often since they are rarely used and a simple function.I am sure someone knows better than I.I want to learn as well.
Old Mar 24, 2010 | 07:20 AM
flippermtc's Avatar
Car: 88 IROC T-Top
Engine: 5.7
Savo110 the problem you probably have is your solenoids have gone bad. That is the issue i had. You need to take the rear side panels off and see if your solenoids actually retract when you push the release button..In some cases something will hold up the cable or the cover and a adjustment is required. In my case i had a bad solenoid and had to find a replacement..I couldn't find anyone that would rebuild the solenoid for me.
Old Mar 24, 2010 | 09:20 AM
Savo110's Avatar
Car: '91 rs
Engine: 305 tbi
ok I'll look first for the fuse, then pull off the rear side panels if that isn't the culprit. Thanx. If "acuators" are bad. Would ones they use for door locks be a good replacement since they longer manufacture the oem ones?
Old Mar 24, 2010 | 09:49 AM
flippermtc's Avatar
Car: 88 IROC T-Top
Engine: 5.7
Savo110,
Good question...I don't know if you could use them...I never looked in to it but i have heard you can possibly use the style used on the rear hatch release.
Old Mar 24, 2010 | 08:32 PM
rext's Avatar
I would like to see a wiring schematic of the convertible tonneau top circuit.There has to be a relay that allows the actuators to cycle to open the lid and then retract?They dont just stay in the energized position when you hit the switch or you would be able to hear them go back and forth each time if you hold the switch and let up....I think!I may be wrong.Its been a long time since I had the same car 18 years ago but thats what I remember.
Old Mar 24, 2010 | 10:34 PM
Savo110's Avatar
Car: '91 rs
Engine: 305 tbi
Whoo hooo! Figure my problem with the switch. The fuse was fine and so were the actuators. The latch pull down in the trunk on my car doesn't work. There is a white push switch that deTects if the trunk is closed or not. I guess it's bad when the tunk and toneau cover smashes into one another. So I Jimmy rigged to switch to come in contact with trunk itself instead of the latch pull down component. So now the toneau is fully functioning. Thanx fellas.
Old Mar 25, 2010 | 05:58 AM
rext's Avatar
Congrats on that one!! I will have to look at mine as well.
Old Apr 27, 2010 | 11:05 PM
Raymon's Avatar
Car: 1989 IROC-Z convertible
Engine: 5.0
Transmission: Borg Warner T5
Axle/Gears: Yet to be determined
The relay is located in the console, behind and to the riight of the switch. It is attatched to the parking brake assembly. The wires to the selinoids go to the front. There are manual releases on both sides. Fold the rear seats forward to find them. They are black, look a little like fishing line, and have finger loops.
I will post the wiring diagram when I get a chance to get to my other garage and scan it.
As I said, in an earlier post, I see this set-up as redundant. The switch opens the tonneau so it can be lifted manually to manually put up the top. Having had a T-top car, I much rather have this switch open the deck lid. But, as mentioned earlier, for some unknown reason, vert deck lids are heavy. Much heavier than the hatch on a coupe.
1992 Trans Am
May 10, 2023 07:19 PM
GTAman
Mar 15, 2019 11:40 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
tcarlos13
Interior Parts Wanted
Sep 2, 2015 07:29 PM
Dialed_In
Aug 20, 2015 01:45 PM
