Possible fix for broken spoiler mounting studs
Old May 10, 2016 | 12:35 AM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
Took the plasma cutter and blew out a few quick squares with 4 holes to help give the epoxy something to hold on to. Tack welded 1/4" X 2" long bolts to the plates on one side so i can bent the bolts to match the slope of the spoiler. I will let yall know how it works.
Attached Thumbnails Possible fix for broken spoiler mounting studs-img_20160510_002301.jpg
Old May 15, 2016 | 07:34 PM
Lar98ss's Avatar
Car: 68 Coupe, 69 RS/SS, 91Vert, 98Vert
Engine: Several
Re: Possible fix for broken spoiler mounting studs
They look good and should work
Old Oct 27, 2017 | 07:43 AM
FART_NUGGETS's Avatar
Car: 1989 Iroc-Z Convertible
Axle/Gears: 2.73:1
I know this is a year old post.
Nice work.
Do some wings have 5? Or are you adding one? My wing was pulling away, I removed it, 2 studs were stripped with cracked up bases, one base was completely detached, and one stud/nut was actually still working But I had 4 on mine. 1989 Iroc.
I have it 3M taped on right now.
How did this work out? I'm about to try something similar. I really need to learn how to weld.
I was thinking of laying in a 4" X 6" square of fiberglass with a stainless stud poking thru the middle. This should be stronger than the plastic wing, and if I rough up the wing real good it should stick forever. Is this a bad idea?
Old Oct 27, 2017 | 10:52 AM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
https://www.thirdgen.org/forums/body...aired-fyi.html
Old Oct 27, 2017 | 12:31 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Only way to fix those spoilers is to remove them. They're nothing but trouble.
Old Nov 1, 2017 | 12:19 PM
Axle/Gears: 2.73:1
I love your car. Sorry to read about the fire. Hope it all works out. That work you did to remove the wrap around wing was phenomenal.
Old Nov 1, 2017 | 02:43 PM
Arctic White 91 RS's Avatar
Car: 91 RS/ 99 T/A/ 72 Vette/ 02 Z28
Engine: LSx/ Dart400
Transmission: M6/ M6/ TH400/ 4L60E
Axle/Gears: 4.10's / 3.08/ 2.73
I've been told by a body shop that the urethane windshield adhesive is strong enough to remount the spoiler. Getting it positioned correctly and avoiding squeeze out might be an issue. In any case, the urethane windshield adhesive works great for mounting hood louvers that don't have any studs left.
Old Nov 1, 2017 | 05:34 PM
Engine: 350 TPI L98
Transmission: WC T5
Is that stuff a parts store item?
Old Nov 1, 2017 | 09:25 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Should be able to buy a tube of windshield sealer for about 15 at any auto parts store.
1992 Trans Am
Interior Parts Wanted
23
Mar 10, 2017 03:14 PM
ken3983
May 31, 2016 03:16 AM
brett89
May 23, 2016 06:50 PM
punkmaster98
Exterior Parts for Sale
May 9, 2016 09:48 PM
dixie wrecked
May 3, 2016 10:58 AM
