Am I missing the ends of the rear bow?
Old Apr 29, 2020 | 09:43 PM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
So I got a weatherstripping kit and the rear bow is shorter than the new weatherstrip piece that has these "smooshed" ends with a screw hole metal tab mount. If I center the weatherstrip on the rear bow top hold down pin and run the weatherstripping along the bow, it comes out way long (thought that gap needs to be filled) and I have nowhere to mount the ends of the strip to.
Old Apr 30, 2020 | 08:11 AM
my82roc's Avatar
Car: 89 Iroc Convertible
Re: Am I missing the ends of the rear bow?
Before I removed my rear bow seal the ends extended past the bow.
Old Apr 30, 2020 | 11:58 AM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
I will look at my 89 when I get access to it(couple days, maybe).
Old Apr 30, 2020 | 08:00 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
The ends need to touch the B pillar/frame or whatever its called.There should be a little L shaped bracket on the seal ends.The bracket screws to the B-pillar frame. FWIW that design lacks a bit to desire.
Old May 7, 2020 | 06:20 PM
tavert91's Avatar
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
84 1LE has it right. The design is poor but it is what it is. I cut mine down and used the "metal tabs" at the ends by making a new hole in the gasket end at the cut and putting a new screw into the threaded hole in the frame piece. Has held up for years like that.
Old May 7, 2020 | 08:37 PM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
What brand is the weatherstrip in question?
Old May 7, 2020 | 09:51 PM
Engine: 350 TPI L98
Transmission: WC T5
It's Metro. And yes, I found where the tabs go! It does seem lanky but I see where it hooks up.
Old May 28, 2020 | 10:53 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
This post got me thinking, a tiny hinge would work much better, since it will allow the bow end to rotate with the hinge.Well, i couldnt find one small enough.So i got these home depot specials instead, in the center OEM bracket.The small cables were my first attempt at making a functional part, but the cables are too rigid.Not giving up on that one yet, but if anyone knows where to find hinges about the size of the bracket, post up.
Had to modify it.
Fully open, no more bending/twisting.
Down/closed.
Improved alignment/contact.
Old Jun 4, 2020 | 07:05 PM
jburden's Avatar
Car: 1988 Camaro Convertible
Engine: 5.0 liter
Transmission: Automatic
Yes, it's a very poor design. I have gone through 2 seals in the past 3 years. No matter how careful I am sooner or later the metals tabs just rip out of the rubber. I am actually designing and prototyping a set of bow extensions that would fasten to the bottom bow and allow the gasket to be fastened to the extension... see attachment for my 3D printed prototype.
Old Aug 15, 2020 | 03:28 PM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
Any updates on this? Thanks.
Old Sep 14, 2020 | 07:29 AM
rinnue's Avatar
Car: 1991 Camaro RS Convertible
Engine: 355 Vortec TPI
Same issue here. Man, this is frustrating.
I'm curious, how does the rear bow seal attach on other brand convertibles?
I'll have to start looking close at car shows and parking lots.
Old Sep 18, 2020 | 07:43 PM
rinnue's Avatar
What do you all think about an end cap that slides over the weather stripping?
The end cap would have a tab to mount it to the pillar with the screw.
The end cap would not wrap around the bottom of the weather stripping so it can still seal to the tonneau.
The cap would attach to the weather stripping with 3m black weather stripping adhesive on all sides except the bottom.
Should be able to 3D print one.
Old Sep 18, 2020 | 08:27 PM
yankeecarman's Avatar
Car: 1991 Trans Am convertible
That seems like a very good fix to me.
Old Sep 18, 2020 | 10:24 PM
rinnue's Avatar
After looking closer at this weather stripping end. It is more of an odd shaped triangle. So a "cap" could only go on 2 sides. Not really a cap at that point
You guys having any luck with your test parts?
Iroczracer
Fabrication
Feb 7, 2008 01:44 PM
86Z
Apr 5, 2005 08:40 AM
LeeH
Apr 21, 2004 10:56 AM
white91Z28
Jun 16, 2003 10:20 AM
