'89 5.7 GTA convertible project
Old Oct 24, 2022 | 04:00 PM
Paintchips97's Avatar
Car: '84 TA, '88-89 GTA convertibles
Engine: 406ci SBC, LB9, L98
Transmission: T56, 700r4s
Axle/Gears: 3.73 10 bolt, 3.27 9 bolts
Been searching for a GTA convertible for well over a decade now, and finally landed on a solid, clean 5.7 car. I've been trying to get it put back together. I bought it from a good friend who inherited it from his father who, unfortunately, passed away in the middle of some work on the car. Right now I have the interior gutted with lots of new parts going back in over the winter. One thing I'm really struggling with is the tonneau release system, which even if it were working properly would likely get annoying with the button on the dash. Is there any way I could put a discreet button on either the cover itself (like the 91-92 cars) or the interior side panel just below it? I used to have a '91 and liked the location of that switch a lot. I'm just not sure if it'd be as simple as running a new 12v line back to the switch and then to the solenoids, or must there be relays involved? I'm not overly concerned about the trunk interlock, I never intend to sell the car and I'm very familiar with what happens when you open the tonneau into the trunk. Originality isn't of much concern either, while I will be repainting the ground effects Flame Red like factory it's still lightly modified under the hood (Edelbrock aluminum heads and lower intake, SLP runners, Holley throttle body and longtubes)
Old Oct 29, 2022 | 08:37 AM
Big&BadGTA's Avatar
Engine: 5.7L L98 TPI
Transmission: 700r4 Automatic
Re: '89 5.7 GTA convertible project
Very cool!
Old Oct 29, 2022 | 09:31 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Glad to see you posting it here!
Old Oct 29, 2022 | 06:47 PM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
I’m 3000 miles from my 1989 IROC Z Vert(305/LB9 TPI Auto Trans) car. IIRC there are just two wires connected to my OE Tonneau
release switch. You could properly attach two wires to the switch harness and run them to your desired second switch location. Buy a “momentary contact, normally open two pole switch” and install.
there is a good thread on thirdgen.org about repairing the tonneau release system to operate.
advise how it works out!
Old Oct 29, 2022 | 06:50 PM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
PS Nice Vert!
Funny how Pontiac offered 350’s in Verts, but Chevy did not. AFAIK
Old Oct 29, 2022 | 08:22 PM
my82roc's Avatar
Car: 89 Iroc Convertible
Originally Posted by mikeceli
PS Nice Vert!
The Pontiac 350 convertibles were all dealer converted cars.
Pontiac didn’t release a “factory” convertible till I believe 1991 and those were all 305’s
Old Oct 29, 2022 | 09:06 PM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
Makes sense Camaro and Firebird would have the same engine constraints.
Old Oct 30, 2022 | 01:04 AM
Reddragon88gta's Avatar
Engine: 5.7 L98
That is a really cool looking GTA convertible! Looks like it has some nice mods and will be great car when you get it back together.
Old Nov 3, 2022 | 08:17 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
It is just a momentary switch, so adding a second switch should not be impossible, or difficult for that matter. All you need to do is wire into the switch on the dash and go from there.
Keep in mind you do not want to just wire directly to the solenoids thru the switch as the switch would probably burn out, I think the better way would be to just wire into the dash and use the harness that is there but you could get another relay to power it.
Old Nov 4, 2022 | 09:37 AM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
Why add a switch on the dash, when OP wants an easier to reach switch, then the console switch?
Up high and centered, where it can be reached, while standing outside the car, ready to grab the tonneau cover and raise it up. IMO.
Old Nov 4, 2022 | 11:44 AM
my82roc's Avatar
Or just get a tonneau cover from a 91-92 car with the switch cutout already there
Steve R
Feb 19, 2025 01:59 PM
85@IRocZ
Nov 30, 2018 05:55 PM
blacksunshine'91
Oct 15, 2016 02:49 PM
chazman
Mar 15, 2016 04:21 PM
xzqvn9
Jul 17, 2011 11:29 AM
