LT1 Fans vs. L98 Fans
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
my car stays around 230* while idling with or w/o a/c. it takes it a while to cool if and when it does. what is the difference between L98 fans and LT1 fans? are the LT1 fan motors rated at a higher wattage or something? the L98 fan blades are the exactly the same as LT1's(same part #). the LT1's fans are loud as hell, when the are going full blast. my l98's fans, when going full blast, can barely be heard.
can anyone help?
can anyone help? Joined: Jul 1999
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Yeah dude, I think you're not pulling enough power or soemthing.. My L98 dual fans are pretty damn loud..
-- Joe
-- Joe
Yes, stock LS1 fans, over 5000 CFM when both are on full. That was as high as our velocity tool went. Probably pulls more than that though. Never tested LT1 or L98 fans. The LT1/LS1 stuff is shrouded better though, and thus perform better.
GP
GP
Car: 1988 IROC-Z
l98 fans shrouded? hahaha what shroud? i too am skeptical that any aftermarket company makes a dual fan setup that pulls more air that the stocker. i am leaning towards warn/old fan motors in my case. they are the originals from 1988. i think it might be time to replace them both even though they work. what do you guys think? :sillylol:
Car: 1988 IROC-Z
Originally posted by 89WS-6
You can test it with an electrical tester. See how many volts are coming off of the negative wire going from the fan to a ground. If it is anywhere above 1 or 2 volts, you should look into a fan.
thanks for the help everyone
i will try this today after i get home from school. Thread
codeysabatini
Nov 10, 2015 04:07 PM
gta892000
Sep 16, 2015 12:37 AM
