I need to fix my leaky radiator
Old Jun 27, 2002 | 11:53 AM
5SIZ's Avatar
Car: 1987 IROC-Z
My Radiator leaks, at first it was little puddles here and there, but now it leaks mid sized puddles and I have to start carrying a bottle of water with me, what can I used to temporaraly seal my radiator until I can buy a new one? " it leaks from the bottom"
When I buy a new radiator "probably an autozone one" Is it difficult to swap radiators?? or is it a direct pull out and put in type of deal?? Or is it cheaper to get mine fixed?
Old Jun 27, 2002 | 01:00 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
They have some crap that you can put in the radiator that will stop the leak, but it is only temporary. Also, that stuff isn't that great. I can't remember the name but if you go to Autozone, Checkers, etc..you find it on the shelf with the other additives. Oh yeah, if you put it in, do a flush after you put the new radiator in.
As for the radiator, it is very easy to remove. Should be just a simple replacement. I did mine in about 20 minutes.
Old Jun 27, 2002 | 02:06 PM
mrt89rs's Avatar
From: Tucson AZ where the 3k ft of elevation kills your time
Car: 89 camaro rs
Engine: 383 .06 over
Transmission: th350
Axle/Gears: 3.73 10 bolt
sweet thanks dude
Old Jun 27, 2002 | 06:32 PM
1MEAN92RS's Avatar
Car: '92 Rally Sport
Engine: LO3
Bars Leaks!!!! Thats what the stuff is called. It's great, won't clog or turn your coolant nasty colors. I believe I was told once that GM put the equivalent of a bottle of that stuff into every car that comes off the assembly line. It will help lubricate your water pump too and prevent corrosion. I had a small pinhole leak around my waterpump after replacing it last summer and I wasn't about to take it back off for just a drop or two. Bars Leaks did the trick and I only used half a bottle.
Old Jun 28, 2002 | 10:49 AM
SpeedCat86's Avatar
Car: '86 TransAm WS6
Transmission: Custom TH700R4
Bar's will work, but only on the metal parts of your radiator. Most of our rad's have plastic tanks, wich are prone to developing pressure cracks.
Swapping a radiator is easy. The most difficult part is getting the tranny cooler lines hooked back up. You have a 5-speed, so this is a non-issue for you.
Old Jun 30, 2002 | 03:50 AM
patrick sieben's Avatar
Don't put bars in the radiator! Get a new radiator or fix the one you have. I managed to fix mine by take away a few of the fins leaving enough room to put a metal-epoxy compount between the two tubes after I cleaned to bare metal.
Old Jun 30, 2002 | 03:53 PM
mrt89rs's Avatar
Car: 89 camaro rs
Transmission: th350
Patrick:
a little to late for that, I put a tube of bars leaks the other day and I have no more leaks! I'll get a new rad and flush my system in the next couple of weeks
Old Jun 30, 2002 | 09:31 PM
Twelvz's Avatar
Car: 89IROC
Engine: Forged 355 AFR195
Transmission: 700R4 Vigilante Converter
Axle/Gears: Strange 12 bolt 3.73
I gotta replace mine in my 92, what radiator did you replace yours with?
I'm worried about fitment issues...
Old Jul 1, 2002 | 09:42 AM
SpeedCat86's Avatar
Twelvz: Welcome to the board! Always good to find ThirdGenners in this area.
As for the radiator, I have a stock replacement aluminum/composite radiator I got from PepBoys. I've been abusing it pretty good since March, and it seems to be holding up well.
Some parts places cary an all brass/copper radiator, but I had lots of trouble with those leaking around the joints. I ditched the last one when one of the heater hose fittings fell off and I didn't feel like breaking out the soldering torch again.
Old Jul 1, 2002 | 03:06 PM
mrt89rs's Avatar
Car: 89 camaro rs
Transmission: th350
speedcat86,
where do you guys go to meet at in norfolk?
my brother is in the navy and lives in norfolk. although right now he is on leave when he comes back he is going to want to go out cuzin or something. He has a 94 trans am and loves to race last time that i was out there some frind of his took us out to milatry highway and I-64 i think and said that people where allways out there raceing but i did not see anybody. oh and one more thing do you guys have a track aroung that area?
Old Jul 1, 2002 | 09:41 PM
SpeedCat86's Avatar
Yeah, the meet at Janaf Center (Millitary and I-64) got busted up by the cops a few months ago.
I usually hang out with the folks from Coastal V6 and HRRacing.com. We usually start off at the Saturday night Cruise-in at Giant Square on Independance Ave, in Pembroke (north of VA Beach Blvd) Lots of classics, muscle and Hot Rods. That goes every week from 3:00 untill 9:00, and then we usually go out from there. We tend to avoid the main drag at the beach this time of year, cause it's wall-to-wall tourists and traffic is a bie-otch. Some of the more popular hangouts are over in Newport News. The cops over there actually keep the Ricers away from the Domestics, and keep us away from the lot the imports hang out at.
The Barnes&Noble on Constitution & VB also attracts some late night action.
The only track I know of that's 'local' is back up 64 just past Williamsburg. There may be others, but I'm an autocrosser, and I never went looking for a drag strip.
See you on the street!
Speedcat86 (VA: TOMCAT 6)
Old Jul 1, 2002 | 11:54 PM
mrt89rs's Avatar
Car: 89 camaro rs
Transmission: th350
yeap that was it "janaf" i remember the big red sign on top of that shoping center that said "JANAF' hahaha that is cool i will email my brother and let hem know thanks man.
It will be a long time before i go out there agian you see i live in tucson az and i wont be going down there again for a wile, atleast till my bro gets back.
oh and one more ? have you ever heard of a mustang car club named universal stangs? because that was the name of the car club that my bros frind sarted along whit some other dude.
Old Jul 2, 2002 | 05:44 AM
FAST85Z28's Avatar
Here's my 0.02.. when you do go buy a radiator, stay away from Autozone radiators
Old Jul 3, 2002 | 12:36 AM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
Can we say J B WELD, worked for me when my end cap craked.
Bubbajones_ya
Jul 6, 2024 08:32 PM
Bohemian
Aug 15, 2017 05:11 PM
92firebirdguy
Sep 1, 2016 07:53 AM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
gta892000
Sep 16, 2015 12:37 AM
