strange cooling problem
Old Jul 17, 2002 | 07:41 PM
5.7L OF JUSTICE's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7L TPI
My car seems to start running hot once I've been driving a while. The strange thing is that it heats up more when I am moving, not at idle. The car actually cools down when I am stopped at a light for a while. What would cause this? I dont have the air dam in front is this why? Any suggestions would be helpful.
Old Jul 17, 2002 | 08:04 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Re: strange cooling problem
yes put the air dam back on, regardless of what iroc22 says
Old Jul 18, 2002 | 08:39 AM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
Re: Re: strange cooling problem
I would normally be hesitant about taking advice from some hill billy Texan, but he's right. :sillylol: The air damn is a must.
Old Jul 18, 2002 | 09:47 AM
i demand you take that comment back, i live more 10 minutes away from a rural area
Old Jul 18, 2002 | 11:46 AM
streetrunner's Avatar
my car did that once make sure to ahve the coolant system filled with coolant or water (water is cheaper but boils quicker than coolant) if you dont have enough coolant in it than the system wont cool no matter what high priced high performance coolign prducts you ahve. i filled up my cooling system and the prob went away only to come back b/c my raditor leaks.
Old Jul 18, 2002 | 02:55 PM
Engine: 5.7L TPI
I have no problem with a coolant leak, its always full. If I do need an air dam where can one be purchased and how much are they?
Old Jul 18, 2002 | 09:10 PM
your local chevy dealer
Old Jul 20, 2002 | 02:58 PM
Sciguyjim's Avatar
I've heard prices for used dams of about $20. If you can find some reasonably stiff, yet flexible, rubber sheet or strip, you may be able to make your own. Just find a way to attach it at the bottom front of the radiator. It should stick down into the airflow maybe 6" I think. Also, angle it forward a little bit if possible, think of a small snow plow. Angling it toward the rear will not work. Then get used to parking without hitting it on curbs or wheel stops.
chazman
Aug 28, 2018 03:25 PM
Infested
May 22, 2018 11:56 PM
someone972
Aug 30, 2015 12:52 AM
red90IROCls1
Aug 25, 2015 06:56 AM
overdriv
Aug 20, 2015 03:52 PM
