DOH!!!! i rounded off my temp sensor bolt
Old Jan 6, 2003 | 01:56 PM
rockfourone's Avatar
ok, in the middle of my 305 to 350 swap, i took the temp sensor off the 305 block and went to put it on the 350. when i went over to my 350, i noticed there was a bolt to plug the hole. no biggie right. so i just get my trusty 9/16 open end and DOH!!! i rounded it off. tried everything, vice grips, pliers, the works. wont come out. can i relocate my temp sensor somewhere else? there is another bolt in the same place on the other side but i dont want to round it off too, and its tight. help?!!!
Old Jan 7, 2003 | 11:01 AM
MdFormula350's Avatar
i would maybe cut the bolt head into like a flat head screw driver slot and mabe try and get it out that way..
Old Jan 7, 2003 | 11:43 AM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
Try a pipe wrench
Old Jan 8, 2003 | 11:42 PM
c4boom's Avatar
Car: 87 iroc and 88 k2500 tbi truck
Engine: l98 and lo5
Transmission: 700 r4's babby
i would get me a 1/2" nut (iner dia. not wrench size) and i would weld that thing on to the bolt. then it WILL come out if you can weld . that or you can try a bolt extractor not a ez out cuz they suck, get a real one
Old Jan 9, 2003 | 04:16 PM
Camar92's Avatar
Car: 1986 IROC-Z
Engine: Vortec 350 with mild cam
Transmission: 700r4 Mild build
Axle/Gears: Stock
wow, welding a nut on the bolt! That is a great idea! Im only 17, so im still learning! Thanks. As far as I know, just as long as the temp sensor is in the block away from the combustion chamber, it will be fine. This may be incorrect, just what ive heard. might help you, hope so!
Cleotiz
Jan 6, 2018 08:56 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
bamaboy0323
Aug 15, 2015 07:20 AM
Elliswon
Aug 10, 2015 12:33 PM
