weird overheating issue
Old Jun 26, 2003 | 07:27 AM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
My car overheated last night for the first time and it was kinda weird. I went out for a drive just because it was nice outside and I had to go down the street to get some crack ( ) . The car ran fine, heated up to 200 then dropped to 180 and stayed there. Then all of a sudden the temp just started to rise and it was getting close to 260* just as I pulled into the driveway. The fans were on and the radiatior is full. Brand new water pump too. What made it just spike up all of a sudden like that?
Old Jun 29, 2003 | 11:55 AM
Engine: LB9/383
TTT.
anyone?
Old Jun 29, 2003 | 12:00 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
perhaps its the crack that did it?
i donno... why dont you see if something broke or happened as you pulled in? is it still overheating?
Old Jun 29, 2003 | 02:06 PM
dale davidson's Avatar
maybee broken guage, t stat , fan switch problems, or probably a cracked head i think
Old Jun 29, 2003 | 06:42 PM
Engine: LB9/383
It only seems to do it if I drive the car 'hard'. If I get into the throttle any more than Grandma would it seems to get the temp up. Maybe a fuel mixture problem?
Old Jun 29, 2003 | 06:58 PM
RPM WOT L 98's Avatar
Check your timing, how the car running. If the timing is off then you're getting too much timing at WOT and that can cause sudden overheating.
Or a bad head gasket...
Old Jun 30, 2003 | 12:14 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
wait wait wait...
are you saying that if you blip the thottle the temp goes skyhigh and it dropps after you stop messing with the thottle??
LOL... its somthing with the gauge or sender if thats the case.... the car isnt changing temps that quick...
Old Jul 1, 2003 | 07:17 AM
Engine: LB9/383
It's not if I blip the throttle. It's if I drive it hard, put more load on it for a few minutes of so, the temp slowly rises. Once I park the car and let it idle it slowly drops to normal.
Old Jul 19, 2003 | 08:21 PM
ES87iroc's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Tony,
Check out the timing, it makes a world of difference.
BTW, sorry I didn't make it out last weekend, I am just getting back from vacation tonight. (BFE, upstate NY)
TheTraut88
Sep 11, 2015 05:16 AM
383cam
Sep 9, 2015 06:01 AM
Fronzizzle
Sep 8, 2015 12:10 PM
Accerrito22
Sep 5, 2015 09:34 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
