Anyone have any cooling problems with an underdrive crank pulley?
Just as the title says, how did your car react as far as coolant temps go after you installed an underdive pulley?
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Originally posted by 25THRSS
Do you also have an underdrive alternator pulley?
damn, and you still have charging issues? What does the volts drop to and what is your idle speed?
A 25% under crank with a smaller alt pulley, I still think the alt is underdriven by 3%. You may not notice it. Depends how much electronic stuff your running.
I would recommend the smaller alt pulley with the stock crank to anyone running a big stereo setup.
ah, thanks for the info. You think my stock 105 amp would handle it?
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
no problems with March underdrive pullies. i gt he power and amp set.
but m alternator is a 140amp powermaster. and my water pump is a high flow--
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I installed a 3 piece march clear powdercoated set and I didn't have have a problem with cooling... course I'm running a 31x19 radiator with 2 permacool fans on the back and a 10 inch pusher on the front with the stock water pump.
ambainb
Apr 25, 2016 09:21 PM
Navy8125
Aug 22, 2015 07:13 PM
Street Lethal
Aug 12, 2015 11:33 AM
