"High" Position A/C-Heater Switch Problem
Old Mar 2, 2005 | 10:59 PM
Capitol Bill's Avatar
Car: 89 Pontiac Firebird/87 Olds 442
Engine: 2.8/450 Olds
Transmission: 700R4/THM 400
The a/c-heater blower motor in my 89 2.8 Firebird will not operate when the a/c-heater switch is turned to "high". The switch, however, causes the blower motor to operate in the "low" and "medium" positions. Recently, I replaced the switch, the blower motor and the relay (with the coiled wire) with all new parts and installed all of them at the same time, but the blower motor still would not operated in the "high" position of the switch. I was told that I might have to run a wire directly from the connections on the wire terminals of the "high" position of the switch to the corresponding terminal connections on the blower motor. Has anyone on this forum had any experience with this problem. Your input would be greatly appreciated. Capitol Bill
Old Mar 12, 2005 | 07:19 AM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
what "relay " did you replace?
Old Mar 12, 2005 | 07:41 AM
Sorry, I should have said that I replaced the resistor which is located on top of the fan motor asembly; not the relay. Capitol Bill
Old Mar 12, 2005 | 09:24 AM
Dave Y's Avatar
Engine: 4.3L V6
if thats the case, it sounds like there is a problem with the blower high relay, power feed, relay itself, ect.
Old Mar 12, 2005 | 11:10 PM
Dave, where is that relay located? In the Blower motor assembly or in the engine bay somewhere? Can you tell me where it is located and what it looks like or what wiring harness is in ? I am assuming that it is a relay that you are talking about?Thanks! Bill
Old Mar 13, 2005 | 01:36 AM
Dave Y's Avatar
Engine: 4.3L V6
ok, it is in the engine compartment, should be screwed to the blower case somewhere, IIRC it is a silver or gold metal relay with 4 wires, two of which are heavy red wires
Old Mar 27, 2005 | 04:16 PM
89BlueRS's Avatar
Car: 89 Camaro RS
Engine: LO3 305 TBI
I'm having this same problem. It's kinda strange. I'm going to try to replace the resistor. The relay wasn't the problem when I changed that.
Old Mar 30, 2005 | 05:52 PM
To: Dave Y-- Thanks for your info and interest. I just got back from Arizona today and just got done reading your message, so I haven't had a chance to check the relay out.
To: Blue89RS-- You can try the resistor which I hope will solve your problem, but in my case, I tried two new resistors and neither solved the problem. Can you tell me exactly where the relay is you checked and waht color it is and what color wires run to it? Thanks, Bill
Ghettobird52
Jul 5, 2024 11:18 PM
Bryan F
Aug 18, 2015 02:28 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Fronzizzle
Aug 9, 2015 01:15 PM
